carlossa52(at)gmail.com Guest
Posted: Sun Jul 29, 2012 7:51 am Post subject: rivets vs UHMW |
Hello, allWhen riveting UHMW to aluminum, on which side goes the rivet head? Thanks Carlos CH601-HD, plans
psm(at)att.net Guest
Posted: Sun Jul 29, 2012 8:10 am Post subject: rivets vs UHMW |
Hi Carlos,
I don't think it matters which end of the rivet contacts UHMW. However, that stuff is so soft you might need a metal washer between the rivet head and the plastic.
On my plane the only plastic used in structural places is nylon.
Paul
Camas, WA
On 7/29/2012 8:47 AM, Carlos Sa wrote:
[quote]Hello, all When riveting UHMW to aluminum, on which side goes the rivet head? Thanks Carlos CH601-HD, plans
JohnDRead(at)aol.com Guest
Posted: Sun Jul 29, 2012 6:43 pm Post subject: rivets vs UHMW |
The head should be against the softer material.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 7/29/2012 9:51:31 A.M. Mountain Daylight Time, carlossa52(at)gmail.com writes:
| Quote: | Hello, allWhen riveting UHMW to aluminum, on which side goes the rivet head?Thanks CarlosCH601-HD, plans
aouellet(at)icecanada.com Guest
Posted: Mon Jul 30, 2012 7:17 am Post subject: rivets vs UHMW |
UHMW is also a structural material it can withstand impact and can be used as a bearing material.
It also has been proven to be a good wearing surface against abrasion.
Proof of that can be seen in snow plow were the UHMW make the surface against which the snow roll out of the way above the road scraping blade
Also hockey rink sides, liner in quarry hoppers and silos as well as sliding and rotary bearing surfaces.
I happen to design stuff with that type of materials and it is all in how you apply it to a particular situation.
Just my two cents... You mileage may vary
Alain
