f.kyle(at)sympatico.ca Guest
Posted: Fri Jul 27, 2012 9:20 am Post subject: panic attack - 914 |
I attempted to detach the instrument panel (designed to do that,
courtesy mod) but in the process managed to leave a fitting and denuded it
of its connectors.
The fitting is the orange 3-wire which engages the carb common
pressure tube across the engine - the purpose to read and act on the common
pressure. I can find nothing to describe this wiring arrangement in my
paperwork and of course need to do so on re-fitting the panel.
The three wires are green, white/red and black and are tipped with
pins to fir the firewall receptor. Thing is, I don't know which is who.
Any advice gratefully received.
Thnaks, Ferg
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
7.59 KB |
Downloaded: |
282 Time(s) |
h&jeuropa
Posted: Sat Jul 28, 2012 3:36 am Post subject: Re: panic attack - 914 |
Ferg,
I think you are referring to the airbox pressure sensor, correct? The wiring harness from Rotax that connects the sensors to the TCU has all white wires that have numbers printed on them. The airbox pressure sensor numbers are 9, 33, 21 (the static pressure sensor numbers are 6, 30, 1 . I'm thinking that a connector has been inserted in your harness to make the firewall penetration. I think you should be able to determine which color wire is which number at the TCU. At the airbox sensor, looking at the sensor from the top (where the writing is) with the wires pointing towards you, 21 is on the left, 33 the center and 9 is on the right.
Hope this helps! We could fly over this weekend and help except we're not set up to cross the border. Maybe come to Niagara Falls?
Jim & Heather
