ADS600-B vs. Transponder Antenna Locations...
Site Admin
PostPosted: Sun Jul 22, 2012 6:09 pm    Post subject: ADS600-B vs. Transponder Antenna Locations... Reply with quote
Dear Listers,
The manual for the NavWorx ADS600-B says that the normal transponder antenna and the UAT antenna "MUST be at least 5 feet apart". On an RV-8, that presents somewhat of a problem. Realistically, the farthest forward you can mount a transponder fin is just behind the main spar under the aileron pushrods. 5 feet back from that point is right under the rear-mounted battery box! That means that the next realistic place is right behind the elevator bellcrank and behind bulkhead F-808. The coax w/ TNC connector on one end that comes with the ADS600-B is just long enough to make it to the forward position. I was thinking of mounting the transponder antenna (Garmin GTX-237) in the aft position as described above and using RG-400.
But that's pretty far back for a transponder antenna. I've never seen one mounted there before. Any reason why I wouldn't want to mount it there?
The only other option would be to mount it out on the wing somewhere to maintain the 5' separation. But that's even goofier, it seems to me...
Thoughts?
Status: 110+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Tim Olson
PostPosted: Sun Jul 22, 2012 6:55 pm    Post subject: ADS600-B vs. Transponder Antenna Locations... Reply with quote
I'd do what it takes to put them 5' apart. The transponder and AD-B are high wattage and put out a lot of RF. Not familiar with your mounting locations on that model but either antenna should work basically anywhere on the belly just fine....even back just forward of the rudder. So I'd just buy some RG-400 and find a spot that is 5' away, is easy, looks ok, and gives options should you add some other antenna like APRS or any other future antenna. Should be doable.
On Jul 22, 2012, at 9:09 PM, Matt Dralle <dralle(at)matronics.com> wrote:
Dear Listers,
Thoughts?
aarongleixner(at)sbcgloba
PostPosted: Mon Jul 23, 2012 4:23 pm    Post subject: ADS600-B vs. Transponder Antenna Locations... Reply with quote
On my RV-8A, I had the same issue with the lower cost traffic system I installed back in 2003. I used the recommended coax in the installation manual for the Bendix King transponder for the length of cable I installed, and mounted the transponder antenna with a doubler near one of the bulkheads near the tail (on the belly). Works fine and maintains the 5 ft separation.
Aaron
To: rv-list(at)matronics.com; rv8-list(at)matronics.com; rv7-list(at)matronics.com; rv10-list(at)matronics.com
Sent: Sun, July 22, 2012 10:17:01 PM
Subject: ADS600-B vs. Transponder Antenna Locations...
--> RV10-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Dear Listers,
Thoughts?
Status: 110+ Hours Since P//www.matronics.com/Navigator?RV10-List" target=_blank>http://www.matroni========================
