Electrical Connections
Phoenix3(at)cox.net
PostPosted: Thu Jan 12, 2006 7:08 pm    Post subject: Electrical Connections Reply with quote
Hi,
I am ready to connect the five wires of my Ray Allen trim servo to the
five wire cable which is routed to the control/trim indicator on the 701
panel. Aircraft Spruce says that the conductor material is 26 gauge
silver plated wire. I was planning to solder with lead free solder and
then insulate with electrical tape. Is this sufficient? If not, what
is a better way to go? Thanks.
Chuck Kyle
p.mulwitz(at)worldnet.att
PostPosted: Thu Jan 12, 2006 7:54 pm    Post subject: Electrical Connections Reply with quote
I'm not sure about the solder choice, but I would strongly recommend
"Heat Shrink" tubing rather than electrical tape.
You can get a nice assortment of heat shrink tubing from Harbor
Freight for almost nothing. Select a piece of tubing a bit larger in
diameter than your solder joint and a couple of inches long and place
it on the wire before soldering. Pre-tin the wires and form them in
a double U or J shape so the mechanical strength of the joint is a
function of the wire strength and the solder holding it all
together. Before the final solder heating it should look like two
fish hooks pulling on each other. Crimp the hooks with pliers to make
a firm connection and then heat the whole joint while adding
additional solder. I use a 25 watt soldering iron - really cheap
ones are only a few dollars. After it is cooled slide the heat
shrink tubing over the joint and heat it with a heat gun (I use one
designed for stripping paint, but anything that makes a lot of very
hot air will work fine). The tubing will shrink to form a very solid
joint. You will need to rotate the wire/tubing combination a little
to shrink the whole tube.
You may also want to enclose the 5 wires in a larger piece of heat
shrink as well. This will be easier if you cut the wires on one
cable to different lengths so all the joints don't wind up on top of
each other.
Good luck,
Paul
XL wings (Recovering electrical circuit designer)
Chuck Kyle
Ron Lendon
PostPosted: Thu Jan 12, 2006 9:42 pm    Post subject: Re: Electrical Connections Reply with quote
Another idea for the heat gun. Fabricate a deflector, imagine a U shape of about 3" dia and 3" wide of sheetmetal attached to the nozzle of the heat gun. This will dam the air from the gun so you don't have to rotate the wire while heat shrinking. See attached picture.
Heat Shrink Air Dam.
 Filesize:  576.05 KB
 Viewed:  995 Time(s)
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
bryanmmartin
PostPosted: Fri Jan 13, 2006 2:44 am    Post subject: Electrical Connections Reply with quote
I used crimp on butt splice connectors. I found the size I needed at Radio
Shack. I would not recommend using tape to cover the splice. Use heat shrink
instead. It would also be a good idea to stagger the splices so they dont
all stack up in the same spot. Then you can cover the entire splice area
with another piece of heat shrink. Leave a loop of wire at the splice site
so that in the unlikely event that you ever have to replace the servo,
you'll have enough wire available for the new splices after you cut off the
old ones.
Bryan Martin
do not archive.
on 1/12/06 10:04 PM, Charles Kyle at Phoenix3(at)cox.net wrote:
Hi,
Chuck Kyle
Bryan Martin
do not archive.
shilocom(at)mcmsys.com
PostPosted: Fri Jan 13, 2006 4:31 am    Post subject: Electrical Connections Reply with quote
My heat gun came with this type of deflector, but it was much smaller. More
like a 1 to 1 1/2" diameter and width so you can get to wires in a tighter
place. I still like crimp sleeves and knife connectors. Bob U.
Bill(at)flyinmiata.com
PostPosted: Fri Jan 13, 2006 8:42 am    Post subject: Electrical Connections Reply with quote
You can combine the best of both ideas with heat shrinkable butt
connectors. Del City has them, I'm sure other places do, too. They also
have some dielectric goo in them to seal the connection.
TurboDog's Dad
Bill Cardell
www.flyinmiata.com
1-800-FLY-MX5S
970-242-3800
Crvsecretary(at)aol.com
PostPosted: Fri Jan 13, 2006 4:20 pm    Post subject: Electrical Connections Reply with quote
Del City??
Got a web address ?
Thanks very much.
Tracy Smith
Naugatuck, CT
601xl N458XL (reserved)
In a message dated 1/13/2006 6:17:22 PM Eastern Standard Time,
Bill(at)flyinmiata.com writes:
TurboDog's Dad
Bill Cardell
www.flyinmiata.com
1-800-FLY-MX5S
970-242-3800
PostPosted: Fri Jan 13, 2006 4:40 pm    Post subject: Electrical Connections Reply with quote
http://www.delcity.net/ specifically
http://www.delcity.net/delcity/servlet/catalog?parentid=195161&page=1
TurboDog's Dad
Bill Cardell
www.flyinmiata.com
1-800-FLY-MX5S
970-242-3800
Del City??
Got a web address ?
Thanks very much.
Tracy Smith
Naugatuck, CT
