sarg314(at)gmail.com Guest
Posted: Sat Jul 07, 2012 10:14 pm Post subject: screen in sump? |
The checklist I am using for my annual inspections says "remove, clean, inspect oil suction screen in sump". Where in an Lyc. O-360 is the oil suction sump? I have an oil filter on the engine, so don't confuse this with the engine oil screen. There is no oil screen in the engine because that was replaced with the oil filter. Is there another screen in the sump and if so how do I get to it?
Tom Sargent
vanremog(at)aol.com Guest
Posted: Sat Jul 07, 2012 10:57 pm Post subject: screen in sump? |
The Lycoming O-360 series suction screen is accessed by removing a hex headed cap plug on the rear near the bottom of the sump. In the PC-106 Parts Catalog please ref Figure 25 Find No. 21.
-GV
Posted: Sun Jul 08, 2012 3:53 am Post subject: screen in sump? |
Tom,
When you do find it (other post had a good description), remember to replace the crush gasket, I buy oil filters, crush gaskets and Oil analysis kits in matching batches – usually 6-pack as the oil filters come that way at a discount.
If you still can’t find it let me know and I’ll get a picture for you…
Ralph
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Sunday, July 08, 2012 2:14 AM
To: rv-list
Subject: screen in sump?
Tom Sargent | Quote: | | http://www.matronics.com/Navigator?RV-List | 01234567
Posted: Sun Jul 08, 2012 5:09 am Post subject: screen in sump? |
Ralph,
What size is the crush gasket? I’m putting an Aircraft Spruce order together and I may as well get some now.
Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen
Sent: Sunday, July 08, 2012 7:54 AM
To: rv-list(at)matronics.com
Subject: RE: screen in sump?
Tom,
Ralph
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of thomas sargent
To: rv-list
Tom Sargent012345678901234567
Kellym
Posted: Sun Jul 08, 2012 5:34 am Post subject: screen in sump? |
From the referenced thread,
"STD-111 Gasket, 1 in ID x 1 1/4 in ID x 3/32 Annular.
I believe it might also have an AN 900 number...
A whole 58 cents from AERO.....
http://www.aeroinstock.com/products/GASKET/5598/48371/product_detail/index.html
.also cross references to a MS35769-21 on the AERO site....
But, if it's 1.00 inch ID (and the plug has a 1.0 diam thread) then the
correct cross-reference is MS35769-16 or the older AN900-16 number - and
is a whole 39 cents from Aircraft Spruce."
On 7/8/2012 6:09 AM, Carl Froehlich wrote:
Ralph,
Carl
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Ralph E. Capen
*Sent:* Sunday, July 08, 2012 7:54 AM
*To:* rv-list(at)matronics.com
*Subject:* RE: screen in sump?
Tom,
Ralph
<mailto:owner-rv-list-server(at)matronics.com>
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *thomas sargent
*Sent:* Sunday, July 08, 2012 2:14 AM
*To:* rv-list
*Subject:* screen in sump?
Tom Sargent
*http://www.matronics.com/Navigator?RV-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
KCHD |
dan.pat.b(at)gmail.com Guest
Posted: Sun Jul 08, 2012 7:09 am Post subject: screen in sump? |
Tom:On a Lyc 360 it's a metal, reuseable, "finger" filter - accessed by removing a hex-head cap (the filter will come out with the cap) on the back of the engine, right side and down low - not the easiest thing to get at and difficult to safety wire when reinstalling - helps to temporarily remove SCAT tubing connecting the right side heat muff to the heater box - clean it with solvent - be careful puttting it back in - it's easily crushed if you don't fully seat it before tightening the cap. Hope this helps!
Cheers,
Dan Bergeron
RV-7A - N307TB
320 hours since
1st flight on 8/4/09
On Sun, Jul 8, 2012 at 9:32 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote]--> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
But, if it's 1.00 inch ID (and the plug has a 1.0 diam thread) then the correct cross-reference is MS35769-16 or the older AN900-16 number - and is a whole 39 cents from Aircraft Spruce."
Ralph,
Carl
*From:*owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] *On Behalf Of *Ralph E. Capen
*To:* rv-list(at)matronics.com (rv-list(at)matronics.com)
Tom,
Ralph
*From:*owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) <mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)> [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] *On Behalf Of *thomas sargent
*To:* rv-list
Tom Sargent
*[url=http://www.matronics.com/Navigator?RV-List*]http://www.matronics.com/Navigator?RV-List*[/url]
*[url=http://www.matronics.com/contribution*]http://www.matronics.com/contribution*[/url]
get="_blank">http://www.matronics.com/Navigator?RV-List
le, List Admin.
Paul Valovich
Posted: Sun Jul 08, 2012 8:18 am Post subject: screen in sump? |
On my IO-360 facing forward it’s the safety wired cap on the right side of the sump. Getting to it and re-safety wiring it is a PITA.
Posted: Sun Jul 08, 2012 1:53 pm Post subject: screen in sump? |
AN900-16 AN GASKETS MS35769-21
Is what I ordered...
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Sunday, July 08, 2012 9:09 AM
Ralph,
Carl
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com] ([email][mailto:owner-rv-list-server(at)matronics.com][/email]) On Behalf Of Ralph E. Capen
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Tom,
Ralph
To: rv-list
Tom Sargent0123456789012345678901234567
Posted: Sun Jul 08, 2012 8:13 pm Post subject: screen in sump? |
Thanks for the responses. I ordered the lyc. parts manual.
Tom Sargent
