sstearns2(at)yahoo.com Guest
Posted: Thu Jul 05, 2012 7:41 am Post subject: oshkosh |
Anyone flying into Oshkosh? I am planning on being it the homebuilt camping area Friday to Sunday in my TR-1 taildragger.
Scott
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
ftyoder(at)yoderbuilt.com Guest
Posted: Thu Jul 05, 2012 10:17 am Post subject: oshkosh |
Hi Scott,
I am not going this year but I am wondering if you are planning on flying
non stop? As I recall, you have 100 gal. capacity. Have you ever taken off
with the tanks full?
Tim
galinhdz(at)gmail.com Guest
Posted: Thu Jul 05, 2012 5:15 pm Post subject: oshkosh |
I wanted to go but I have to go to a family wedding instead. Hopefully next year. [img]cid:323(at)goomoji.gmail[/img]
PS, I have 92 galon capacity in my airplane and have flown with it at max gross (2500) a few times. It climbs a little slower but still at around 900-1000ft/min in a "normal" day.
Galin
On Thu, Jul 5, 2012 at 10:40 AM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
| Quote: | --> KIS-List message posted by: Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)>
Scott
rget="_blank">http://www.matronics.com/Navigator?KIS-List
http://forums.matronics.com
le, List Admin.
100 Bytes |
5963 Time(s) |
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Thu Jul 05, 2012 7:23 pm Post subject: oshkosh |
Physically I won't be able to make it again this year but mentally I will be there every minute for the entire week.
Bob Reed
To: kis-list(at)matronics.com
Sent: Thu, July 5, 2012 8:15:22 PM
Subject: Re: oshkosh
I wanted to go but I have to go to a family wedding instead. Hopefully next year. [img]cid:1.4214013574(at)web180102.mail.gq1.yahoo.com[/img]
Galin
Scott
le, List Admin.
y
100 Bytes |
5962 Time(s) |
Posted: Thu Jul 05, 2012 10:42 pm Post subject: oshkosh |
Hi Tim,
If I were going solo I would go non stop for sure. It is about 9 hours and 75 gallons from Camarillo, near los angeles, no wind, going direct. The most I have taken off with half full mains which is about 10 gallons a side and 25 gallons a side in the rear tanks which makes 70 gallons. I was doing aft CG testing.
My girlfriend is going with me which limits us to about 3 hour legs. Maybe someday i can talk her into using the lady J.
Scott
On Jul 5, 2012, at 11:17 AM, "F. Tim Yoder" <ftyoder(at)yoderbuilt.com> wrote:
Hi Scott,
I am not going this year but I am wondering if you are planning on flying non stop? As I recall, you have 100 gal. capacity. Have you ever taken off with the tanks full?
Tim
Posted: Thu Jul 05, 2012 10:47 pm Post subject: oshkosh |
Hi Galin,
How did you do the fuel tanks to get 92 gallons? I am probably going to build a 4 place with a 540 and I want as much fuel as possible in the wing. I am thinking 150 gallons with a fully wet wing and the aileron bellcrank in the wingtip.
Scott
On Jul 5, 2012, at 6:12 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]I wanted to go but I have to go to a family wedding instead. Hopefully next year. <323.gif>
Galin
On Thu, Jul 5, 2012 at 10:40 AM, Scott Stearns <[url=mailto:sstearns2(at)yahoo.com]sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)[/url]> wrote:
Posted: Fri Jul 06, 2012 6:21 am Post subject: oshkosh |
Posted: Fri Jul 06, 2012 6:44 am Post subject: oshkosh |
Scott;
Rich and I opened the bay behind the main spar. It holds an additional 20gal per wing. We made a 2" x 1" gravity fed cross feed under the spar so the rear tank empties into the front tank without any additional selector valves or fail point. We also put a vent between the front and rear tank so the fuel flows nicely between the tanks if needed. We also put a fuel drain in the "cross feed" point but I have never had any water there since the actual low point of the system remains the original one.
When you fill the tanks you can hear the "gurgling" as the rear tank fills. If you fill the tank quickly, the level will drop as fuel balances out by flowing from the front tank to the rear tank. I normally fuel one wing then go fuel the other wing. Then I top them off if needed. I normally only fill to 30galons a side but if I find cheap fuel, I fill it up and get about 10-11hrs of flying with the cheaper fuel. I feel the cost of adding the tanks more than paid for itself in fuel savings.
I will put pictures of what we did on our webpage www.puertoricoflyer.com.
Galin
On Fri, Jul 6, 2012 at 1:47 AM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
[quote]Hi Galin,
Scott
| Quote: | I wanted to go but I have to go to a family wedding instead. Hopefully next year. <323.gif>
Galin
On Thu, Jul 5, 2012 at 10:40 AM, Scott Stearns < (sstearns2(at)yahoo.com)sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
Posted: Fri Jul 06, 2012 9:12 am Post subject: oshkosh |
Hi Galin,
How many bays behind the spar did you use for fuel?
How much fuel do you think you would have if all the bays were used?
Scott
On Jul 6, 2012, at 7:43 AM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]Scott;
Galin
On Fri, Jul 6, 2012 at 1:47 AM, Scott Stearns <[url=mailto:sstearns2(at)yahoo.com]sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)[/url]> wrote:
| Quote: | Hi Galin,
Scott
On Jul 5, 2012, at 6:12 PM, Galin Hernandez <[url=mailto:galinhdz(at)gmail.com]galinhdz(at)gmail.com (galinhdz(at)gmail.com)[/url]> wrote:
Galin
On Thu, Jul 5, 2012 at 10:40 AM, Scott Stearns < (sstearns2(at)yahoo.com)[url=mailto:sstearns2(at)yahoo.com]sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)[/url]> wrote:
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
Posted: Fri Jul 06, 2012 11:42 am Post subject: oshkosh |
That would be a fun trip, non stop! Of course, having your girlfriend along
can be more fun!
I flew into Camarillo in 93 to visit Rich's shop prior to purchasing my kit.
I was also there in 97 or early 98, Rich was rebuilding the IO-240, and I
made templates of his baffling in order to build mine. It's a nice airport.
Hope you have a good trip!
Tim
Posted: Fri Jul 06, 2012 2:04 pm Post subject: oshkosh |
I only used the top rear bay in each wing. They hold slightly over 20gal each. If I had opened the lower rear bay I could have gotten another 10 galons per wing for a total fuel capacity of 110 gal. At least that is what Rich told me when we did it. The trick was the gravity crossfeed. Simple, effective and impossible to fail. It was another one of Rich's brilliant ideas.
I posted some pictures of what we did at:
http://www.puertoricoflyer.com/extended_range.html
Thinking back I should have done the full 110 gallons while the wing was open, but hindsight is 20/20.
Galin
On Fri, Jul 6, 2012 at 12:13 PM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
[quote] Hi Galin,
Scott
| Quote: | Scott;
Galin
On Fri, Jul 6, 2012 at 1:47 AM, Scott Stearns <[url=mailto:sstearns2(at)yahoo.com]sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)>[/url] wrote:
| Quote: | Hi Galin,
Scott
Galin
On Thu, Jul 5, 2012 at 10:40 AM, Scott Stearns < (sstearns2(at)yahoo.com)[url=mailto:sstearns2(at)yahoo.com]sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)>[/url] wrote:
kentpyle(at)iland.net Guest
Posted: Sat Jul 07, 2012 8:07 am Post subject: oshkosh |
Kent will be in Home built parking, Kent
Posted: Sat Jul 07, 2012 9:47 am Post subject: oshkosh |
If anybody passes by the Houston area, let me know. You have a place to "crash" for a night or two. OK, maybe not "crash" but spend a night or two. [img]cid:gtalk.35C(at)goomoji.gmail[/img]
Galin
On Sat, Jul 7, 2012 at 11:06 AM, Kent Pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
[quote] --> KIS-List message posted by: "Kent Pyle" <kentpyle(at)iland.net (kentpyle(at)iland.net)>
593 Bytes |
5946 Time(s) |
