gas tank slosh
icubob(at)gmail.com
PostPosted: Tue Jul 03, 2012 5:49 am    Post subject: gas tank slosh Reply with quote
hi all,
 i have a gas tank slosh question.
 i am leaning more lately to hauling 93 octane from a gas station to my hangar. i usually fill from the mogas pump at my airport and haul back to the hangar in 5 gal cans anyway. got started on this while calibrating fuel gauges, measuring fuel cap. etc. and now find it no more trouble than taxiing to the pumps. plus station gas is 2 octane higher[no ethanol like airport fuel] and $.70/ gal cheaper.
 anyway.................what is anyones experience sloshing metal containers? i did a por 15 on a cycle tank once and was satisfied, no problems in years. i would never pour from these tanks. i have a pump set up with a glass filter.i think i have read tank looks clean after the cleaner must coat it anyway. i have several gerry cans and outboard tanks that would work well and i think more crash proof than plastic but all haven't been used in years and have some rust now.
 then again 5 gal. plastic cans are only $15 a piece.
 any opinions?
   bob noffs
MichaelGibbs(at)cox.net
PostPosted: Tue Jul 03, 2012 7:08 am    Post subject: gas tank slosh Reply with quote
I can't answer your question about sloshing metal gas cans but I did want to point out that auto fuel octane and avgas octane are not measured in the same way. You cannot directly compare the two numbers.
Mike G.
Phoenix, AZ
Kitfox IV-1200 Speedster, Kitfox Series 6
On Jul 3, 2012, at 6:49 AM, bob noffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
[quote]hi all,
 any opinions?
bob noffs
tp://www.matronics.com/Navigator?Kitfox-List
cs.com
matronics.com/contribution
lcfitt(at)sbcglobal.net
PostPosted: Tue Jul 03, 2012 9:48 am    Post subject: gas tank slosh Reply with quote
Bob,
I have always used the plastic cans because I felt there would be less chance for damage if not handled exactly right. The problem with plastic cans available now - at least in California - the child/adult proof cans are pieces of junk. I have never spilled more fuel than I now do with these spill resistant super safety designed cans. The nozzles are impossible. I routinely cut out the safety latch system, but then the nozzle is so short they are worthless when refueling a car - can only empty the first half of the fuel. On the airplane, if the internal valve would seal properly, I guess they would be OK on the wing, but not tested here yet.
Lowell
Sent: Tuesday, July 03, 2012 6:49 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com) ; avid_flyer(at)yahoogroups.com (avid_flyer(at)yahoogroups.com)
Subject: gas tank slosh
hi all,
any opinions?
bob noffs
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
icubob(at)gmail.com
PostPosted: Tue Jul 03, 2012 1:23 pm    Post subject: gas tank slosh Reply with quote
mike,
 yes, i understand the rating differences.mogas at 93 octane has the same rating as avgas at 97-98 octane.
     bob noffs
On Tue, Jul 3, 2012 at 12:48 PM, Lowell Fitt <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)> wrote:
[quote] Bob,
Lowell
hi all,
 any opinions?
   bob noffs
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
Pat Reilly
PostPosted: Tue Jul 03, 2012 1:43 pm    Post subject: gas tank slosh Reply with quote
Bob, Sounds like you already answered your own question. Por 15 is the only slosh I'd use. I used it on a motorcycle tank with similar results as you. I used Kreem on a street rod tank and had it come off in large patches. But, I wouldn't use slosh unless I had to. There is no way to be sure the tank is completely preped. Plastic gas cans are so inexpensive that even slosh would cost more.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Bob,
Lowell
hi all,
 any opinions?
   bob noffs
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
taildragon(at)msn.com
PostPosted: Tue Jul 03, 2012 5:27 pm    Post subject: gas tank slosh Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Lowell, you might look for some 5 Gallon Fuel Jug W/Hose Utility found at most Motorcycle shops. It is what I have been using with good success. Here is a link showing what I am suggesting:
http://item.mobileweb.ebay.com/viewitem?itemId=180905118739&siteId=0&isClassified=false
Roger
icubob(at)gmail.com
PostPosted: Tue Jul 03, 2012 6:37 pm    Post subject: gas tank slosh Reply with quote
lowell,
 i have a wooden box attached to top of my step ladder. set the 5 gal can in it , then use a ''jiggle pump'' to empty contents into wing or cowl tank. takes 2-3 minutes. never spill a drop.
 last week i set up a 12 volt fuel pump [carter] mounted on a table and a separate hand held switch. i have a filter on the end that goes in the tank. pumps a gal./ minute. makes it easy to fill to filler neck and instant off when i flip the switch. and surprising there is stuff in the glass filter already. i may use just the pump with the filter.
 bob noffs
On Tue, Jul 3, 2012 at 8:26 PM, Roger Standley <taildragon(at)msn.com (taildragon(at)msn.com)> wrote:
[quote] Lowell, you might look for some 5 Gallon Fuel Jug W/Hose Utility found at most Motorcycle shops. It is what I have been using with good success. Here is a link showing what I am suggesting:
Roger
PostPosted: Tue Jul 03, 2012 8:17 pm    Post subject: gas tank slosh Reply with quote
Roger,
Thanks for the tip. I have seen those before, but thought they were converted water containers and didn't know where to find them.
Lowell
Sent: Tuesday, July 03, 2012 6:26 PM
Subject: Re: gas tank slosh
Roger
PostPosted: Tue Jul 03, 2012 8:20 pm    Post subject: gas tank slosh Reply with quote
Bob, I have thought of an electric pump. Every catalog that has them I look and dream. Always used the plastic cans with a towel on the wing. Also always fueled at home through a Mr. Funnel. Lots of food for thought.
Lowell
Sent: Tuesday, July 03, 2012 7:36 PM
lowell,
bob noffs
Roger
----- Original Message -----
Sent: Tuesday, July 03, 2012 10:48 AM
Bob,
Lowell
hi all,
any opinions?
bob noffs
Guy Buchanan
PostPosted: Tue Jul 03, 2012 8:25 pm    Post subject: gas tank slosh Reply with quote
The off-road guys have been getting hefty fines for using these in
SoCal. Idiotic, I know, but there it is. If it doesn't say DOT approved
can you're out of luck. Welcome to California.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
cliffh(at)outdrs.net
PostPosted: Wed Jul 04, 2012 4:39 am    Post subject: gas tank slosh Reply with quote
What ever you use make sure it is well grounded.
I built a metal 15 gal tank with a electric pump.
I thought that I had everything well grounded and then got a shock off of the rubber hose. The gas flowing through the hose was creating static electricy. I had to ground the hose nozzle to the pump frame and the landing gear and the pump frame to the hanger metal frame.
Floran Higgins
Helena, Mt
Speedster
912ULS
rick(at)5mike3.com
PostPosted: Wed Jul 04, 2012 5:06 am    Post subject: gas tank slosh Reply with quote
Guy, have you considered moving to New Hampshire Smile
Happy 4th!
approved can you're out of luck. Welcome to California.
Guy Buchanan
Ramona, CA
Vic Baker
PostPosted: Wed Jul 04, 2012 5:11 am    Post subject: gas tank slosh Reply with quote
Well advised Floran, after feeling the hair on my arm raised from static electricity while fueling from a non-metallic tank years ago I would never use anything except a metal "safety" tank for aircraft fueling. (ground it to the aircraft frame and fuel cap by momentarily touching both before removing fuel cap) Or your method with a well grounded tank and nozzle.
Vic
Vic Baker
Carson City, Nv
Series 7 912ULS Warp
Vic Baker
Series 7
Carson City, Nevada
Lynn Matteson
PostPosted: Wed Jul 04, 2012 7:35 am    Post subject: gas tank slosh Reply with quote
When I was building my plane, this subject of static came up and I
soldered some 1/4" braided and plated copper strap to the fuel tank
filler necks. I ran the braid down the wing and attached it to the
rear wing pivot point. This was prior to covering the wing, so the
job is very well concealed.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1303 hrs... (since 3-27-2006)
On Jul 4, 2012, at 9:10 AM, Vic Baker wrote:
[quote] Well advised Floran, after feeling the hair on my arm raised from
Vic
Vic Baker
Carson City, Nv
Lynn
Kitfox IV-Jabiru 2200
N369LM
Guy Buchanan
PostPosted: Wed Jul 04, 2012 11:00 am    Post subject: gas tank slosh Reply with quote
rear wing pivot point. This was prior to covering the wing, so the job
Wish mine had been done. I use an external wire to connect the filler
neck to ground whenever I tank. Doubt it's necessary, but I don't want
to try the experiment.
Guy Buchanan
Ramona, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
bobnoffs
PostPosted: Wed Jul 04, 2012 11:43 am    Post subject: gas tank slosh Reply with quote
the other shoe just hit the floor. i have been worrying about grounding. any other advice on that out there?
 bob noffs
On Wed, Jul 4, 2012 at 2:00 PM, Guy Buchanan <gebuchanan(at)cox.net (gebuchanan(at)cox.net)> wrote:
[quote]--> Kitfox-List message posted by: Guy Buchanan <gebuchanan(at)cox.net (gebuchanan(at)cox.net)>
When I was building my plane, this subject of static came up and I soldered some 1/4" braided and plated copper strap to the fuel tank filler necks. I ran the braid down the wing and attached it to the rear wing pivot point. This was prior to covering the wing, so the job is very well concealed.
Wish mine had been done. I use an external wire to connect the filler neck to ground whenever I tank. Doubt it's necessary, but I don't want to try the experiment.
Guy Buchanan
Ramona, CA
target="_blank">http://www.matronics.com/Navigator?Kitfox-List
le, List Admin.
PostPosted: Wed Jul 04, 2012 12:05 pm    Post subject: gas tank slosh Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I guess I'm left wondering what others do when refueling their lawn mower, ATVs, chain saws, weed wackers and most of all, their CARS!!! How is refueling a plane any different?
Lynn Matteson
PostPosted: Thu Jul 05, 2012 2:29 am    Post subject: gas tank slosh Reply with quote
Beats me, but I don't want to find out the hard (expensive) way.
Lynn Matteson
Jabiru 2200, #2062
On Jul 4, 2012, at 4:04 PM, Roger Standley wrote:
[quote] I guess I'm left wondering what others do when refueling their lawn
Lynn
N369LM
