madriver42(at)gmail.com Guest
Posted: Sat Jun 30, 2012 8:26 am Post subject: Soft Start Module on 912ULS |
To answer Peter Thomson's question about the Rotax "Soft Start Modules" available from Rotax.
I was advised by Roger Lee and Rotax (LEAF) in my particular situation that I would probably be as happy with less cost by going to the Bully Hawk / Con Air Soft Start Module as shown on the Rotax product videos.
I installed the "Soft Start" on my Rotax 912ULS early this spring and have been impressed not only with the cold weather starts but now with starts at 90 degrees F plus OAT. As an addendum, it took me longer to remove the cowl than to install the module.
The guys at LEAF and / or Roger Lee can explain why it works by adjusting the timing for start. If you don't understand this give them a call...they were more than happy to answer my questions. My advice is to shop around - there is a vast difference in pricing from the various sources.
I do not have a method to "measure" the results but IMHO I have experienced MUCH smoother starts with the module installed. I did not have a kick back problem before but added the module to remove the harshness of the typical Rotax start.
With the Bully Hawk option you only "add" a strap-on module on top of the ignition modules installed on your engine, connect it in line with the "A" module and hook up the ground and a "control" wire to your start solenoid. All parts and connectors are supplied. Couldn't be simpler and I couldn't be happier.
Still grinnin!
Phil Smith
CH 701 flying
Rotax 912 ULS
peterthomson
Posted: Sun Jul 01, 2012 4:43 pm Post subject: Soft Start Module on 912ULS |
thanks Phil, and pleased at your success woth the Bully Hawk !
Unfortunately, the a/c was caught up in floods, and rats chewed the
wires of both ignition modules, so the cheapest replacement is the
Rotax units.
Peter
