prop
frank goodnight
PostPosted: Mon Jul 02, 2012 12:28 pm    Post subject: prop Reply with quote
[img]cid:1341260087283(at)dclient.mail.yahoo.com[/img] Hi All,
I have a prop that I need to sell.It's a warp drive 64in 3 blade cf . Has nickel leading
edges and, taper tips , bought in 2004 or 5 , 700 hrs no damage nicks, or abrasions
came off a 912 uls pusher, comes with a 2 or 3in prop ext.(I'm at the house-- too hot
at the hanger) can some one that uses this prop on a kolb (Kolb related E- Mail) give
me an idea as to what it might be worth.
Frank
 Filesize:  12.03 KB
 Viewed:  2728 Time(s)
rickofudall
PostPosted: Tue Jul 03, 2012 5:46 am    Post subject: prop Reply with quote
Frank, Does it have the plate and plastic blade blocks or the CNC machined one?
Rick Girard
On Mon, Jul 2, 2012 at 3:28 PM, frank goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
Frank
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
  - Groucho Marx
 Filesize:  12.03 KB
 Viewed:  2709 Time(s)
rickofudall
Prop hub, that is.
Rick
On Tue, Jul 3, 2012 at 8:45 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
Frank
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
 Filesize:  12.03 KB
