AHRS OP-48 Kit
vernon.franklin(at)gmail.
PostPosted: Sun Jun 17, 2012 2:54 pm    Post subject: AHRS OP-48 Kit Reply with quote
Has anyone successfully used the OP-48 AHRS kit with Dynon AHRS?
The instructions specifically mention GRT and Garmin; no mention of Dynon.
So I do not know if it is just going to be a matter of drilling new mount points, or I should send it back.
Anyone have any thoughts?
Vernon Franklin
Kellym
PostPosted: Sun Jun 17, 2012 3:20 pm    Post subject: AHRS OP-48 Kit Reply with quote
You do not want to use it for Dynon, because their AHRS include a
magnetometer which will respond to the elevator bellcrank rod ends, as
well as the autopilot pitch servo. I am going to use mine for mounting
ELT, because it seems sturdier than the ELT mount Vans sells.
Dynon.
Vernon Franklin
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
