ELT Antenna Mount
skywagon
PostPosted: Sun Jun 10, 2012 6:25 pm    Post subject: ELT Antenna Mount Reply with quote
Jeff,
I viewed this late. Your are right, way too much signal blocking structure, but, maybe even worse it is the antenna is positioned horizontally. The polarization of the signal path is all wrong. It must mounted vertically...
I am sure that you figured all this out by now....
Dave
Kellym
PostPosted: Sun Jun 10, 2012 6:35 pm    Post subject: ELT Antenna Mount Reply with quote
How do you know what the antenna orientation will be after a crash? Only
then will orientation matter.
Even then, orientation to the satellite matters more than orientation to
terrestrial receivers.
Any mounting that prevents the antenna from being broken during the
crash will be better than one that lets the antenna be snapped off by
flipping the plane.
On 6/10/2012 7:17 PM, David Lloyd wrote:
Jeff,
Dave
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
skywagon
PostPosted: Sun Jun 10, 2012 9:25 pm    Post subject: ELT Antenna Mount Reply with quote
Kelly,
I think the majority of crashes usually wind up in horizontal orientation.
If the antenna is mounted vertically in front of the vertical stabilizer in
most crashes that part of the airframe has a good chance of staying fairly
intact even upside down.
About the ELT... the older 121.5 broadcasting on the guard band is usually
not heard by a satellite but, overflying aircraft. The newer higher band
units should reach an overhead satellite. It would be interesting to see
how well the contact goes from an antenna that is oriented horizontally and
close the to earth, i.e. crash site.
I wonder if someone on the List would respond that knows the details about
the new ELT's performance under adverse conditions.
D
Kellym
PostPosted: Mon Jun 11, 2012 5:04 am    Post subject: ELT Antenna Mount Reply with quote
The point is we simply don't know orientation of a crash. If on flat
ground it may very well be horizontal, although I have seen a lawn dart
orientation as well. In mountains, vertical is just as likely. 121.5
is no longer monitored by satellite, so only over flying aircraft are
likely to detect unless crash is near ATC facility. It would be
interesting to know what orientation works best with satellites.
On 6/10/2012 10:23 PM, David Lloyd wrote:
<skywagon(at)charter.net>
Kelly,
orientation. If the antenna is mounted vertically in front of the
vertical stabilizer in most crashes that part of the airframe has a
good chance of staying fairly intact even upside down.
usually not heard by a satellite but, overflying aircraft. The newer
higher band units should reach an overhead satellite. It would be
interesting to see how well the contact goes from an antenna that is
oriented horizontally and close the to earth, i.e. crash site.
about the new ELT's performance under adverse conditions.
D
Kelly McMullen
KCHD
grosseair(at)comcast.net
PostPosted: Mon Jun 11, 2012 5:51 am    Post subject: ELT Antenna Mount Reply with quote
Whether or not the ELT works in whatever orientation you install it
really only matters to me if I have a survivable crash.
If my plane "lawn darts" into the ground I'm probably not gonna make it
no matter what my ELT does or doesn't do. On the other hand, if my plane
winds up more or less horizontal there's a good chance of my having
survived and I want that thing working. The ELT manufacturers have
already done the testing and the design. "Use our antenna and install
according to our directions and it will work." ELT antennas are meant to
be installed vertically because that's the orientation in which they work.
John Grosse
OBTW Haven't we gone around on this topic before?
Kelly McMullen wrote:
<kellym(at)aviating.com>
dart orientation as well. In mountains, vertical is just as likely.
stuart(at)stuarthutchison
PostPosted: Mon Jun 11, 2012 6:24 am    Post subject: ELT Antenna Mount Reply with quote
G'day all,
Kelly is right, 121.5MHz satellite monitoring was turned off in early 2009,
but many airliner radios are configured to monitor GUARD 121.5 as a matter
of routine. 406MHz (actually 406.025) is monitored by both a special
payload on a range of geostationary (GEO) satellites and low earth orbit
(LEO) satellites intended primarily for other things. The main advantage of
406 upgrade is the that the transmission is digital. Hence, your digital
databurst (0.44 to 0.54 seconds long, randomised at around 50 second
intervals to avoid repeated over-transmissions and TX at about 5W - much
higher than the old analogue beacons) contains a bunch of useful information
that the Rescue Coordination Centre can use immediately to differentiate one
beacon from another (i.e you). They can then match a bunch of info to the
distress, such as your flight plan. An in-built constant 121.5 swept tone
generator is still required as a homing localisation signal for rescuers.
406 can be homed to, but requires specialised equipment to track the short
databursts.
The GEO satellites orbit the Earth, but at a rate consistent with the Earths
rotation. Hence, they remain in an essentially constant position relative
to the Earth, roughly overhead (about 36km up I think). A GEO satellite will
generally receive your digital databurst and relay it to the RCC
immediately, but can't work out where you are unless your ELT happens to
transmit the GPS position as well (either in-built GPS or fed from the
aircraft NAV system). The SAR situation may then be resolved immediately
with a telephone call to you ... for example if the beacon is accidentally
switched on.
LEO satellites orbit the Earth and may also take the GPS position from your
ELT, but otherwise use Doppler analysis to fix the position. However, a fix
is calculated on both sides of the satellite track. A second satellite pass
on a different track is required to resolve the ambiguity (i.e. there will
be matching fixes to one side of the original track, but they won't match on
the other side). The trouble with this is that the passes are sometimes as
long as 2 hours apart, so it may take quite some time to resolve the
ambiguity and determine where the ELT is transmitting from. The reason 406
is substantially more accurate to Doppler fix than the older analogue 121.5
beacons is that the standard for frequency stability is much higher. Hence,
the annulus for older beacons was about 20km and for new about 5km. I
recommend ELTs or Personal Locator Beacons (PLBs) with in-built GPS as they
dramatically reduce the time to first accurate fix, which may matter if it's
getting dark. Exposure to the elements is often the greater threat, so
there's no advantage in waiting longer than you have to for rescue.
Keep in mind that a great many ELTs don't work at all after a crash because
the COAX gets damaged, so keep that cable run short if possible. On the up
side, no matter whether you're attempting to transmit straight up to the GEO
or sideways to one of the many LEO satellites, your relatively high-power
databurst is likely to be detected quickly, which provides the RCC a LOT of
information about you. They don't necessarily need to fix you by satellite
to work out where you disappeared off radar ... but it is a huge advantage
to the RCC knowing which ELT is actually transmitting !!!
I have a fast two-seat tandem tailwheel with a slider canopy. There isn't
much room between the canopy track and the VS, so my antenna will be bottom
mounted close to the ELT inside. The antenna will be raked back at 30
degrees with a custom-made fairing around the 3/4" x 6" base. In my POV, the
antenna is likely to be on top after crash landing rough enough for me to
depend on it, with the 'donut' radiating towards the GEO satellite. If not,
the LEOs are likely to see in due course. I also carry a GPS PLB.
Hope this helps.
Stu
sprocket(at)vx-aviation.c
PostPosted: Mon Jun 11, 2012 8:22 am    Post subject: ELT Antenna Mount Reply with quote
Great technical comparison.
One thing about 406 (and other VHF/UHF frequencies) is that radio waves tend
to bounce around off of metal/water/rock rather than be absorbed. I'm not
an RF guy, but this effect is seen when using a cellphone in an elevator
(effectively a Faraday cage with small openings for radio waves to leak
out). Is there anything about 406 MHz that makes it better in the SAR
application due to this effect?
What I'm getting at, is does it really matter what polarization is, or
adjacency to metal objects is in a real-world application.... the signal
might just bounce around until it 'leaks out' to the satellite?
Vern
kuffel(at)cyberport.net
PostPosted: Mon Jun 11, 2012 8:26 am    Post subject: ELT Antenna Mount Reply with quote
It has been almost 50 years since I worked for an antenna company but I do
have substantial real-world experience with ELTs.
Antenna orientation doesn't matter in this application. You have on the
order of over 100 db of signal loss before communication with a satellite
becomes difficult. Antenna orientation will cause at most 3 db of signal
loss. A much more important factor is antenna/cable integrity. In a
relatively minor crash almost any location will work. At worst you can
remove the ELT and jury rig a workable antenna. In a major crash (you're
trapped, won't survive long, etc) there is a high likelihood *any* external
ELT antenna will be disconnected.
This is why I advocate ELT antennas be mounted internally. Bad radio
location but a lot better than non-existent. For fiberglass structure a
good location is in the forward part of the tail cone. For carbon fiber and
metal planes you should mount it somewhere in the cabin with a view outside.
For bubble canopies this is easy but even high-wing and tube structures will
work from inside. The 406 MHz signal will pass through any gap larger than
5 inches. Even the non-essential 121.5 MHz signal will be detectable from
short distances no matter what pile of metal randomly surrounds the antenna.
Tom Kuffel
skywagon
PostPosted: Mon Jun 11, 2012 1:35 pm    Post subject: ELT Antenna Mount Reply with quote
Tom,
Great review and what I was hoping would show up on the List......
Thanks, D
___________________________________________________
