cdupuis
Posted: Thu Jun 07, 2012 3:29 pm Post subject: Ignition/kill switch for 447 |
Hi Guys,
Anyone have info on how to stop the 447? Do you ground something in the ignition circuit? What's normally done?
Thanks!
phoenix(at)ja2.so-net.ne. Guest
Posted: Thu Jun 07, 2012 4:00 pm Post subject: Ignition/kill switch for 447 |
Hello
It a normal. Motor has made for running in flying even with open circuit for safety.
while open circuit, motor continues running.
Like a sea boat of Kill Switch, by making short the motor stop.
Sada
On 2012/06/08, at 8:29, cdupuis wrote:
[quote]--> Kolb-List message posted by: "cdupuis" <ctdupuis(at)maine.rr.com (ctdupuis(at)maine.rr.com)>
Hi Guys,
Thanks!
http://forums.matronics.com/viewtopic.php?p=374972#374972
- The Kolb-List --> &n========================
beauford
Posted: Thu Jun 07, 2012 4:23 pm Post subject: Ignition/kill switch for 447 |
Hi Guys,
Thanks!
Brother cdupuis...
Bet you had a fun time with that name in high school, eh...? Beauford was
nearly as bad, I reckon...
Anyway, the 447 kill switch ("shorting cable") wire is black and yellow...
Ungrounded is the "run" condition, ground it to
kill it.
Getting mine to stop running has never been the problem.... Good luck with
yours...
Worth what ye paid fer it...
beauford
FF-076
Brandon, FL
Posted: Thu Jun 07, 2012 4:35 pm Post subject: Ignition/kill switch for 447 |
Hi
Make 2 wires SHORT comes from magnet part of motor. na
Sada
On 2012/06/08, at 9:21, Beauford wrote:
[quote]--> Kolb-List message posted by: "Beauford " <beauford173(at)verizon.net (beauford173(at)verizon.net)>
Hi Guys,
Thanks!
Brother cdupuis...
kill it.
yours...
beauford
FF-076
Brandon, - The Kolb-List --> http://www.matronics========================[b]http://www.matronics.com/co=================
henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Fri Jun 08, 2012 9:58 am Post subject: Re: Ignition/kill switch for 447 |
08jun12
Sir,
To kill the 477 simply short the Black wire to the Yellow... I do this with a toggle switch. In fact two toggle switches wired in series. That way the engine will happily run with both switches open, or one switch open and one switch closed. Both switches must be closed to kill the engine.
This set up is a safety feature. Saved my bacon on my first solo, when I inadvertently hit one of the switches to the closed position while in the air and the engine kept running. Unless you have an electric starter getting the 477 lit again while strapped to the seat can be problematic.
Attached is a simple drawing of two toggle switches in series...
Good luck.
Aloha,
Kill Switch Series.pdf |
54.91 KB |
699 Time(s) |
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
henry.voris
Posted: Fri Jun 08, 2012 10:14 am Post subject: Re: Ignition/kill switch for 447 |
08jun12
Sir,
I believe I mis-spoke in my last post. I said to "short the black wire to the yellow"... I should have said (and drawn)"short the black & yellow wire from the engine to ground". My ground wire runs back to the engine case.
I am on the mainland now, so I'm about 2,500 mile away from my plane and giving you advise from my aged and faulty memory... Sorry.
Now you know why I wish you good luck.
Aloha,
Henry
Do Not Archive |
henry.voris
Posted: Fri Jun 08, 2012 10:24 am Post subject: Re: Ignition/kill switch for 447 |
Revised Drawing Attached
54.97 KB |
688 Time(s) |
Do Not Archive |
cdupuis
Posted: Fri Jun 08, 2012 1:57 pm Post subject: Re: Ignition/kill switch for 447 |
Thanks for the info! Much appreciated. Drawings need to be fleshed out a bit.
Charlie
