jacklockamy(at)comcast.ne Guest
Posted: Sat Jun 02, 2012 10:47 am Post subject: Missing gasket? |
For those with Rotax 582 w/C-Box knowledge… is there a gasket or O-ring to seal where the gearbox mates with the engine block/case? I see what looks like an O-ring in some illustrations, but not in others.
Jack in KW
rickofudall
Posted: Sat Jun 02, 2012 2:56 pm Post subject: Missing gasket? |
No, the mating surface there is dry. All that's in that section is the donut and the connecting shafts between the crankshaft and the gearbox.
Rick Girard
On Sat, Jun 2, 2012 at 1:46 PM, Jack Lockamy <jacklockamy(at)comcast.net (jacklockamy(at)comcast.net)> wrote:
Jack in KW
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
