Mark III Classic wing/boom incidence angles
jackinkeywest
PostPosted: Wed May 30, 2012 7:06 am    Post subject: Mark III Classic wing/boom incidence angles Reply with quote
On the Mark III Classic, with the wing incidence angle set at 9 degrees... can someone tell me what the tail boom angle is?
Need this info as I prepare to install floats on my M3C. Re-installing my own wings and taking the measurements/readings would be a MAJOR undertaking (if not impossible) considering the area/space my plane is currently confined to. Any help by someone able to take those angle readings on their M3C and passing the info along would be MOST APPRECIATED!!! I spoke with Brian at KOLB but they only have a M3X on hand and the measurements are different.
Thanks in advance!
Jack Lockamy
Key West, FL
2009 Kolb M3C (N33040)
Ex-owner/builder Sonerai II
Ex-owner/builder Sonex TD
Ex-owner/builder RV-7A
Ex-50% owner Cirrus SR-20
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  447 Time(s)
Mike Welch
PostPosted: Wed May 30, 2012 7:27 am    Post subject: Mark III Classic wing/boom incidence angles Reply with quote
Jack,
The tail boom is 6.0 degrees. If you are calling the wing's incidence "positive", then the tail boom is negative 6.0 degrees,
BTW, the motor mount in this configuration is 0.0 degrees.
Mike Welch
On May 30, 2012, at 10:03 AM, Lockamy, Jack CIV Atlantic Targets Marine Ops, AD.5.3.3 / Key West Det wrote:
Thanks in advance!
Jack Lockamy
Key West, FL
jackinkeywest
PostPosted: Wed May 30, 2012 10:02 am    Post subject: Mark III Classic wing/boom incidence angles Reply with quote
Perfect! Just what we needed. Thanks Mike...
Jack
DO NOT ARCHIVE
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  420 Time(s)
