gap seals
sstearns2(at)yahoo.com
PostPosted: Mon May 28, 2012 7:29 pm    Post subject: gap seals Reply with quote
I put gap seals on the ailerons, trim tabs, and flaps of my TR-1. I am not sure if the flap gap seals are doing much, maybe a small drag reduction. The aileron gap seals noticably reduced control forces and increase my roll control. I recommend them for the aileron at least. I used the 35mm gap seal for the aileron and flap.
I got them from this guy...
http://www.wingsandwheels.com/page28.htm
I ordered the 78 mm gap seals for the tail feathers but I have not installed them yet. I think there is a noticable drag reduction to be had with gap seals on the elevator and rudder.
Scott
galinhdz(at)gmail.com
PostPosted: Tue May 29, 2012 4:22 am    Post subject: gap seals Reply with quote
On a similar note I started using Bowlus "glider tape" also known as "speed tape" for the small gaps where the wing/fuselage connect, where the wing tips connect to the wings and underneath the fuselage to cover the different inspection panel gaps. With the tape I show a 2kts increase in IAS.
I ordered 3 rolls of the 2" size since I knew I was going to mess up a little until I figured out how to do it correctly. BUT I would up selling one roll to a friend qith an RV-4 and still have one roll left over. Here is a link to where I got it:
http://www.cumulus-soaring.com/bowlus.htm
Galin
On Mon, May 28, 2012 at 10:29 PM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
[quote]--> KIS-List message posted by: Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)>
Scott
rget="_blank">http://www.matronics.com/Navigator?KIS-List
http://forums.matronics.com
le, List Admin.
ftyoder(at)yoderbuilt.com
PostPosted: Wed May 30, 2012 7:37 am    Post subject: gap seals Reply with quote
Hi Scott,
Did you put the seal on the bottom only? Do you have a photo of your
instillation you could send? What tape did you use?
Thanks, Tim
PostPosted: Thu May 31, 2012 8:05 am    Post subject: gap seals Reply with quote
Hi Tim,
I just put tape between the hinges on the side with the hinges. I also had to trim about a 1/4 inch off the flap gap seal since the whistled with the flaps down.  I attached with gap seals with double sided tape and single sided tape running from the skin up over the gap seal as for anti peel. I just followed what the website said to do. I used the double and single sided tape from the website. Not the cheapest, but it is high quality tape. I attached a picture of the flap gap seal before I trimed them.
Scott
To: kis-list(at)matronics.com
Sent: Wednesday, May 30, 2012 8:36 AM
Subject: Re: gap seals
--> KIS-List message posted by: "F. Tim Yoder" <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)>
Hi Scott,
Did you put the seal on the bottom only? Do you have a photo of your instillation you could send? What tape did you use?
Thanks, Tim
 Filesize:  1.38 MB
 Viewed:  4086 Time(s)
lgdavid2(at)verizon.net
PostPosted: Thu May 31, 2012 10:07 am    Post subject: gap seals Reply with quote
Hi Scott,
I remember Vance Jaqua used to say the KIS had a distinctive whistle when it was in the landing configuration. He said you could always tell when a KIS was coming in for a landing. Your comment just reminded me of that.
Larry
On 5/31/2012 9:00 AM, Scott Stearns wrote: [quote] Hi Tim,
Scott
From: F. Tim Yoder <ftyoder(at)yoderbuilt.com> (ftyoder(at)yoderbuilt.com)
Hi Scott,
Thanks, Tim
PostPosted: Thu May 31, 2012 10:33 am    Post subject: gap seals Reply with quote
Scott,
From your experience, I think doing my ailerons for the reduced control force would be desirable.
If you have extra gap seal, 15 yd. roll seems like allot, would you like to sell me enough for my ailerons?
Tim
[quote] -----
Hi Tim,
Scott
Hi Scott,
Thanks, Tim
PostPosted: Thu May 31, 2012 10:58 am    Post subject: gap seals Reply with quote
Just send me your address and I will send you some. Not enough money to worry about and I would like to see if you have the same results.
Scott
Sent: Thursday, May 31, 2012 11:33 AM
Scott,
Tim
[quote] -----
Hi Tim,
Scott
Hi Scott,
Thanks, Tim
PostPosted: Thu May 31, 2012 12:21 pm    Post subject: gap seals Reply with quote
Galin.hernandez(at)dhs.gov (Galin.hernandez(at)dhs.gov)
On Thursday, May 31, 2012, Scott Stearns wrote:
[quote] Just send me your address and I will send you some.  Not enough money to worry about and  I would like to see if you have the same results.
Scott
[url=javascript:_e({}, 'cvml', 'sstearns2(at)yahoo.com');]sstearns2(at)yahoo.com[/url]
From: F. Tim Yoder <[url=javascript:_e({}, 'cvml', 'ftyoder(at)yoderbuilt.com');]ftyoder(at)yoderbuilt.com[/url]>
To: [url=javascript:_e({}, 'cvml', 'kis-list(at)matronics.com');]kis-list(at)matronics.com[/url]
Scott,
Tim
[quote] -----
Hi Tim,
Scott
Subject: Re: KIS-List: gap seals
--> KIS-List message posted by: "F. Tim Yoder" <[url=javascript:_e({}, 'cvml', 'ftyoder(at)yoderbuilt.com');]ftyoder(at)yoderbuilt.com[/url]>
Hi Scott,
Thanks, Tim
