mbcrisp
Posted: Mon May 21, 2012 7:23 am Post subject: Fresh Air Vent |
Does anyone know where I can get replacement air vents for both the pilot and co-pilot. The ones I have now are worn out and broken. The vanes are loose and will close the second you take your hand off of them. The fresh air is really needed on the warm days!! I have yet to find a suitable replacement for this plastic part.
jwellum(at)AOL.COM Guest
Posted: Mon May 21, 2012 8:04 am Post subject: Fresh Air Vent |
I just bought some of the clip in air fresheners to keep the vents from closing. Excel Air sells new vents that are "certified" but they are a little expensive.
new air vents
In a message dated 5/21/2012 10:25:08 A.M. Central Daylight Time, mbcrisp87(at)gmail.com writes:
| Quote: | --> TeamGrumman-List message posted by: "mbcrisp" <mbcrisp87(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=373483#373483
n76lima(at)mindspring.com Guest
Posted: Mon May 21, 2012 8:12 am Post subject: Fresh Air Vent |
| Quote: | I just bought some of the clip in air fresheners to keep the vents from closing. Excel Air sells new vents that are >"certified" but they are a little expensive. new air vents <--Link
| Quote: | >Does anyone know where I can get replacement air vents for both the pilot and co-pilot. The ones I have now are
>worn out and broken. The vanes are loose and will close the second you take your hand off of them. The fresh air is >>really needed on the warm days!! I have yet to find a suitable replacement for this plastic part.
The ones that John S. sells at Excel-Air are DEFROST vents. They are NOT the fresh air vents below the control yokes.
The OEM parts were from some 60's car, and the supply of them ran out several years back. I've seen various alternative vents installed.
--Bob Steward
Birmingham, AL
Posted: Mon May 21, 2012 8:13 am Post subject: Fresh Air Vent |
OOPS , I guess that I should have looked closer at the web site........ I just see the defroster vents now
In a message dated 5/21/2012 11:05:10 A.M. Central Daylight Time, jwellum(at)AOL.COM writes:
| Quote: | I just bought some of the clip in air fresheners to keep the vents from closing. Excel Air sells new vents that are "certified" but they are a little expensive.
new air vents
bhauskne(at)gmail.com Guest
Posted: Mon May 21, 2012 8:17 am Post subject: Fresh Air Vent |
The air vents from Excel Air are outstanding, with much better air control, both volume and direction. They use eyeball style vents, and are modern and attractive, far better than the '70s sedan air vents that were stock.
1. They are well worth the design, construction, and certification cost. I have them and highly recommend them.
2. If we expect to have vendors provide replacement or improved parts for our planes, we need to support them. Flying is expensive, but not having these vendors and parts would be far worse.
3. Excel Air and John, the vent designer, are part of the Good guys, the small group of dedicated companies that support our fleet. Support Them!
Sent from my BlackBerry® PlayBook™
www.blackberry.com
From: "jwellum(at)aol.com (jwellum(at)aol.com)" <jwellum(at)aol.com (jwellum(at)aol.com)>
To: "teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)" <teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)>
Sent: May 21, 2012 9:02 AM
Subject: Re: Fresh Air Vent
new air vents
In a message dated 5/21/2012 10:25:08 A.M. Central Daylight Time, mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com) writes:
| Quote: | --> TeamGrumman-List message posted by: "mbcrisp" <mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com)>
st">http://www.matronics.com/Navigator?TeamGrumman-List
ics.com
.matronics.com/contribution
Posted: Mon May 21, 2012 9:01 am Post subject: Fresh Air Vent |
A temporary fix that's good for a couple of years is to take them out and sand blast the surface. Enough sand gets into the crannies that it works ok for a few years. Other than that, . . . . Garner once told me to look at the vents in motor homes. Some of them are similar.
Sent: Monday, May 21, 2012 8:23 AM
Subject: Fresh Air Vent
httsp; -================
slacktide
Posted: Mon May 21, 2012 11:19 am Post subject: Fresh Air Vent |
Talk to Ken Blackman at Air Mods NW (1-800-PROPELLER). He has a way to make some aftermarket automotive ones fit... little waterjet cut aluminum adapter plates.
On Mon, May 21, 2012 at 8:23 AM, mbcrisp <mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com)> wrote:
[quote]--> TeamGrumman-List message posted by: "mbcrisp" <mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com)>
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
le, List Admin.
pkuhns
Posted: Tue May 22, 2012 5:16 am Post subject: Re: Fresh Air Vent |
I have the Excel air vents (below the yoke) that John used to sell. I think he stopped making those because of manufacturing issues (?). Not sure. Anyway, they're great eyeball types. You might want to call Excel and just see if there are any left stuck in a shelf somewhere.
_________________ N27161, 1979 Grumman (Gulfstream) Cheetah |
gketell
Posted: Tue May 22, 2012 4:35 pm Post subject: Re: Fresh Air Vent |
I have a "brand new", never used set of the vents Ken Blackman at Airmods Northwest used to sell. I won them as a door prize at AYA2006. I no longer have a plane so...
Make me an offer. Figure $9 to ship them to continental US.
Greg K
78.08 KB |
15835 Time(s) |
allenc3(at)bellsouth.net Guest
Posted: Tue May 22, 2012 5:03 pm Post subject: Fresh Air Vent |
$120 including shipping?
n32romeo(at)AOL.COM Guest
Posted: Tue May 22, 2012 7:48 pm Post subject: Fresh Air Vent |
$30? I'll drive by and pick them up....
Rich Harrison
BILL9725(at)AOL.COM Guest
Posted: Wed May 23, 2012 7:46 am Post subject: Fresh Air Vent |
In case this becomes a bidding war for these vents, I think they should be at least $150, even more since we all need them.
So my offer $175 plus shipping, and I know that is a still a good price.
Bill S
In a message dated 5/22/2012 6:04:19 P.M. Pacific Daylight Time, allenc3(at)bellsouth.net writes:
| Quote: | --> TeamGrumman-List message posted by: Claude Allen <allenc3(at)bellsouth.net>
| Quote: | --> TeamGrumman-List message posted by: "gketell" <greg(at)ketell.com>
Greg K
http://forums.matronics.com/viewtopic.php?p=373609#373609
http://forums.matronics.com//files/vents_164.jpg
Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
md11strejo(at)yahoo.com Guest
Posted: Wed May 23, 2012 8:12 am Post subject: Fresh Air Vent |
I'll offer you $190 plus shipping
Scott Trejo
On May 23, 2012, at 10:46 AM, BILL9725(at)AOL.COM (BILL9725(at)AOL.COM) wrote:
[quote] In case this becomes a bidding war for these vents, I think they should be at least $150, even more since we all need them.
Bill S
In a message dated 5/22/2012 6:04:19 P.M. Pacific Daylight Time, allenc3(at)bellsouth.net (allenc3(at)bellsouth.net) writes:
| Quote: | --> TeamGrumman-List message posted by: Claude Allen <allenc3(at)bellsouth.net (allenc3(at)bellsouth.net)>
On May 22, 2012, at 8:35 PM, "gketell" <greg(at)ketell.com (greg(at)ketell.com)> wrote:
Posted: Wed May 23, 2012 9:49 am Post subject: Fresh Air Vent |
Bill,
Why not make a faceplate over the entire airbox. Make it out of .020 aluminum, paint it flat black.
Then install three or four of these per side.
http://www.aircraftspruce.com/catalog/appages/plasticeyeball.php
Lots cheaper.
Gary
Sent: Wednesday, May 23, 2012 8:46 AM
Subject: Re: Re: Fresh Air Vent
Bill S
Greg K
| Quote: | http://www.matronics.com/Navigator?Tea=======================
Discover
Posted: Wed May 23, 2012 10:28 am Post subject: Fresh Air Vent |
Hmmm
I have a brand new set from the factory. Maybe I should cash in...make back what I lost in the stock market...
Come to think of it I have at least one almost new part of everything on a Tiger/ Cheetah. At these prices I'd sure be willing to sell all those parts. Any takers?
Ned
Bill S
gketell
Posted: Wed May 23, 2012 11:04 am Post subject: Re: Fresh Air Vent |
WOW!!! I wish I had more of these things.
I also wish I had set it up as an auction, but I didn't: They went to the first-responder, AllenC3.
GK
Posted: Wed May 23, 2012 1:05 pm Post subject: Fresh Air Vent |
Sure glad I bought them before these guys jumped in. Think these guys must hang out on eBay!
On May 23, 2012, at 2:27 PM, 923te <923te(at)att.net (923te(at)att.net)> wrote:
[quote]Hmmm
Ned
| Quote: | In case this becomes a bidding war for these vents, I think they should be at least $150, even more since we all need them.
Bill S
