another Twinstar Mark II question
lmorgan100(at)charter.net
PostPosted: Thu May 17, 2012 2:27 pm    Post subject: another Twinstar Mark II question Reply with quote
first,
thanks Gene for the response, I will do some hops before I fly to get a
feel for what it wants to do.
My next question is about getting in and out of this thing. I am not as
nimble as I used to be and lifting a leg and bending my head at the same
time is quite a workout. Has anyone tried splitting the windshield in half
with a piano hinge so the windshield could be opened up more ? orany other
ideas for easier access ?
thanks,
Lee..
Time: 12:29:16 PM PST US
Subject: CG on a MK II twinstar
Hi all, I am looking for info on the CG for a MK II Twinstar.
My measurements were done with the bottom of the wing at 9%
I am using a weight and balance sheet from a Kolb Firestar but I think the
calculations are the same for a MK II Twinstar.
I am coming up with a CG of 37 % with me in it, I am 175 pounds, Has anyone
else had to add weight to the front to
get the CG within limits ?
thanks,
Lee..
Time: 06:20:31 PM PST US
Subject: Re: CG on a MK II twinstar
Lee,
I don't have the specific info you ask for but if you are intending to fly
the
Mark II two up, I can tell you you do not want any extra weight up front as
the
elevator on the Mark II is rather underpowered for keeping the nose up at
slower
flight speeds with two up. If it was up to me I'd fly it as is. I can assure
you it will fly just fine with your weight. If you have any doubts just make
the first flight with half a tank of fuel, and you will be more than pleased
with how she flies.
If it flies like the nose is light and must be held down, adjust the
ailerons down
a tad.
Gene
herbgh(at)nctc.com
PostPosted: Thu May 17, 2012 5:09 pm    Post subject: another Twinstar Mark II question Reply with quote
Gull wing doors worked on my MkIII.... Single tube down the
middle...and a frame on each side to support the Lexan...Herb
At 05:26 PM 5/17/2012, you wrote:
first,
thanks,
Lee..
thanks,
Lee..
Lee,
the
the
slower
with how she flies.
ailerons down
a tad.
Gene
cristalclear13
PostPosted: Tue May 22, 2012 1:34 pm    Post subject: Re: another Twinstar Mark II question Reply with quote
lmorgan100(at)charter.net wrote:
first,
That is how my Mark II is built. You might be able to see a little bit of it in this video or maybe one of my other videos. If you want any closer pics let me know and I'll get some.
http://youtu.be/KdnNCubZA8Y
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
jackinkeywest
PostPosted: Wed May 23, 2012 7:31 am    Post subject: another Twinstar Mark II question Reply with quote
Kolb newbie question:
Recent emails indicate there is a Kolb Mark "II" Twinstar model aircraft. I was under the assumption that the nickname "Twinstar" was given to the Kolb Mark "III" Classic aircraft. What am I missing here.
Jack in Key West
Kolb M3C N33040
DO NOT ARCHIVE
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  672 Time(s)
PostPosted: Wed May 23, 2012 8:03 am    Post subject: another Twinstar Mark II question Reply with quote
Jack in Key West
Jack in KW/Folks:
Think you are missing a little history.
First two place Kolb was a Twinstar.
Second was the MKII Twinstar.
Third was the MKIII Twinstar.
There was no "mkIII classic" until The New Kolb Aircraft Company kit'd the
MKIII Extra. TNK gave the MKIII the handle MKIII Classic.
I fly a MKIII Twinstar, built in 1991/92, long before it was renamed by TNK.
jackinkeywest
PostPosted: Wed May 23, 2012 8:44 am    Post subject: another Twinstar Mark II question Reply with quote
John,
That is EXACTLY the information I was hoping to gain/learn from you 'ole timers'... Wink
Makes perfect sense. All the literature I have with my 2009 Kolb Mark III Classic also has 'Twinstar' on it.
Thanks for sharing your knowledge of Kolb history.
Jack Lockamy
Key West
Kolb M3C N33040
DO NOT ARCHIVE
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  642 Time(s)
