cdupuis
Posted: Mon May 07, 2012 12:56 pm Post subject: 447 fuel pump firefly |
could someone send me a picture of how the fuel pump for the 447 is bolted to the firefly frame?
beauford
Posted: Mon May 07, 2012 2:44 pm Post subject: 447 fuel pump firefly |
Brother Cdupuis...
Re: FF fuel pump : Am e-mailing you (Off-List) several shots of how mine (I
use two pumps) are mounted... Hope the photos help...
Let me know if you need more. Good luck with your Fly, sir.
The pix are worth what ye paid fer them...
beauford
FF-076
Brandon, FL
henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Wed May 09, 2012 4:21 pm Post subject: Re: 447 fuel pump firefly |
09may12
Sir,
Attached is a photo showing how the impulse pump is attached on FireFly Five-Charlie-Bravo...
I also have a Facet Pump (electric), in line, closer to the fuel tank.
Good luck.
Aloha, Henry
46.21 KB |
4123 Time(s) |
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
