KingCJ6(at)aol.com Guest
Posted: Mon May 07, 2012 12:37 pm Post subject: Fuel washer |
We have a bad sealing washer that fits on the t-fitting that connects to the outlet of a CJ-6 fuel pump. Sapp/Selby do not have these in stock. Have researched to no avail and believe we are looking for a non-metallic metric flat washer, but the proper material remains a mystery.
This is the closest description found to date, but no idea if “Buna-N� is the right material for gasoline immersed applications.
Description : Item : Sealing Washer, Type : Flat, Material : Buna-N, Thickness : 0.0625", Thickness Tolerance : +/-0.020", Temp. (F) : -25 to 200, Color : Black, Durometer : Shore A: 50 to 70, Application : Cushioning, Sealing and Vibration Resistant
Any ideas on material or possible sources?
Thanks, Dave
Posted: Mon May 07, 2012 1:32 pm Post subject: Fuel washer |
Dave,
As Doug Sapp already said, don't use a Buna-N washer on the fitting. You
need a metric crush washer. Here is a link to some metric crush washer
which may fit the fitting. I'd go with the aluminum crush washers.
http://www.mcmaster.com/#metric-sealing-washers/=hfo1tt
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 5/7/2012 3:34 PM, KingCJ6(at)aol.com wrote:
to the outlet of a CJ-6 fuel pump.Sapp/Selby do not have these in
stock.Have researched to no avail and believe we are looking for a
mystery.
This is the closest description found to date, but no idea if “Buna-N”
*/Description/*/: Item : Sealing Washer, Type : Flat, Material :
Application : Cushioning, Sealing and Vibration Resistant /
Thanks, Dave
cjpilot710(at)aol.com Guest
Posted: Tue May 08, 2012 6:13 am Post subject: Fuel washer |
Some times they use lead washers as seals, much as they do on the air system. They much softer of course than aluminum and will seal better.
Jim "Pappy" Goolsby
