		| Author | Message |
		| recapen(at)earthlink.net Guest
				|  Posted: Tue May 01, 2012 6:16 am    Post subject: [lycoming] Re: Odd running cylinder -  cured! |   |
				| Disassembly and evaluation is on my list of things to do next.....
The injector and restrictor are sitting on my workbench waiting for me to inspect them....
 My prioirites at the time were focused on the fix and the subsequent test flight to determine results - but I didn't throw the parts away when I got back either.
 I'll post the inspection results shortly.
 Great question!
 [quote]--
 | |  |  | - The Matronics LycomingEngines-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?LycomingEngines-List
		| Back to top |  |
				|  Posted: Tue May 01, 2012 6:50 am    Post subject: [lycoming] Re: Odd running cylinder -  cured! |   |
				| I'll do the white cloth - just in case anything falls out.  I'm betting on the scratches personally - I had taken it apart and cleaned the restrictor and line earlier in my search - didn't remove the injector body though.
 Haven't heard about lead deposits in primer lines - my injectors now balance to within .1gph when I go Lean-of-Peak - so I'm inclined to dismiss that as a possibility...especially with only 160 TTSN.  If I need to take them apart again, I'll remember the Hoppe's #9...Thanks!
		| Back to top |  |
