Speedy11(at)aol.com Guest
Posted: Fri Apr 27, 2012 2:04 am Post subject: RV8-List Digest: 1 Msgs - 04/26/12 |
I haven't heard of one, but I've often wondered about it. It would require quite a bit of work.
Do you want it for soft fields?
Stan Sutterfield
In a message dated 4/27/2012 3:03:40 A.M. Eastern Daylight Time, rv8-list(at)matronics.com writes:
| Quote: | I would like a little larger nose wheel than the standard. Anyone know
it this has been done before?
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dennisfox(at)persona.ca Guest
Posted: Fri Apr 27, 2012 5:14 pm Post subject: RV8-List Digest: 1 Msgs - 04/26/12 |
yes that was my thinking, I have an angle valve IO-360, so little extra weight up front.
My home airport is paved, but several in the area are grass, and not quite so smooth as pavement.
Wondering if the RV10 nose fork might be compatible but I don’t know what size of tire it uses.
Sent: Friday, April 27, 2012 4:03 AM
To: rv8-list(at)matronics.com (rv8-list(at)matronics.com)
Subject: Re: RV8-List Digest: 1 Msgs - 04/26/12
Stan Sutterfield
href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List
Posted: Fri Apr 27, 2012 5:39 pm Post subject: RV8-List Digest: 1 Msgs - 04/26/12 |
The RV-10 nose gear is the same size as the 8A main gear – and in my opinion way too big for the 8A. I’ve landed my 8A on many grass strips without a problem.
Carl
RV-8A (800 hrs)
RV-10 (FSDO comes May 23rd for sign off)
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Dennis Fox
Sent: Friday, April 27, 2012 9:14 PM
Subject: Re: Re: RV8-List Digest: 1 Msgs - 04/26/12
Stan Sutterfield
In a message dated 4/27/2012 3:03:40 A.M. Eastern Daylight Time, rv8-list(at)matronics.com (rv8-list(at)matronics.com) writes:
0123456789012
Posted: Sun Apr 29, 2012 8:46 pm Post subject: RV8-List Digest: 1 Msgs - 04/26/12 |
thanks for the reply. Will ponder this for a while.
From: Carl Froehlich (carl.froehlich(at)verizon.net)
Sent: Friday, April 27, 2012 7:38 PM
Subject: RE: Re: RV8-List Digest: 1 Msgs - 04/26/12
Carl
RV-8A (800 hrs)
Stan Sutterfield
0123456789012
