pdelano(at)telus.net Guest
Posted: Thu Apr 26, 2012 6:03 am Post subject: Elevator Rib, holes in crimps |
Hi All,
When drilling for the elevator skin along the spar I forgot to mark that there was a crimp in line with the spar and continued to drill right out to the middle of the flange on the Elevator Tip Ribs, 7h1-5. On the top and bottom I have holes on the edge or into this crimp, see attached photos (these were the worst of the 4 holes and are on the bottom). I email Caleb and hope to get an answer from him. Has anyone else done this? If so, did you order new tip ribs or just move away from the crimp and put a new hole respecting edge distance minimums. Is there a minimum distance from a crimp?
Perry
804.29 KB |
5126 Time(s) |
863.49 KB |
5126 Time(s) |
carlossa52(at)gmail.com Guest
Posted: Thu Apr 26, 2012 7:03 am Post subject: Elevator Rib, holes in crimps |
Perry, I suspect you will have to replace the part.
I don't remember whether that happened to me, but if it did, since I am building from plans, I just made another part and threw the old one away.
You might want to consider making new parts to replace damaged ones, instead of ordering them. For one thing, it's much cheaper, and there are no mail delays...
Good luck
Carlos
(CH601-HD, plans)
On 26 April 2012 10:01, Perry Delano <pdelano(at)telus.net (pdelano(at)telus.net)> wrote:
Hi All,
Perry
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Apr 26, 2012 7:37 am Post subject: Elevator Rib, holes in crimps |
I would remove the crimp and put another crimp just to the side. I've never heard of edge distance from a crimp.
Tommy Walker
On Thu, Apr 26, 2012 at 9:01 AM, Perry Delano <pdelano(at)telus.net (pdelano(at)telus.net)> wrote:
Hi All,
Perry
_________________ Tommy Walker
N25A - Anniston, AL |
Posted: Thu Apr 26, 2012 8:04 am Post subject: Elevator Rib, holes in crimps |
Hi Tommy I like that idea.Thanks Perry Sent wirelessly from my BlackBerry device on the Bell network.Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
Sender: owner-zenith701801-list-server(at)matronics.com
Date: Thu, 26 Apr 2012 10:35:01 -0500
To: <zenith701801-list(at)matronics.com>
ReplyTo: zenith701801-list(at)matronics.com
Subject: Re: Zenith701801-List: Elevator Rib, holes in crimps
I would remove the crimp and put another crimp j= ust to the side. =A0I've never heard of edge distance from a crimp.
Tommy Wal= ker
On Thu, Apr 26, 2012 at 9:01 AM, Perry Delan= o <pdelano(at)telus.net (pdelano(at)telus.net)> wrote:
Hi All,
=A0When drilling for the elevator skin along the spar I f= orgot to mark that there was a crimp in line with the spar and continued to= drill right out to the middle of the flange on the Elevator Tip Ribs, 7h1-= 5. On the top and bottom I have holes on the edge or into this crimp, see a= ttached photos (these were the worst of the 4 holes and are on the bottom).= I email Caleb and hope to get an answer from him. Has anyone else done thi= s? If so, did you order new tip ribs or just move away from the crimp and p= ut a new hole respecting edge distance minimums. Is there a minimum distanc= e from a crimp?
=A0
Regards,=
=A0
Perry
JohnDRead(at)aol.com Guest
Posted: Thu Apr 26, 2012 8:08 am Post subject: Elevator Rib, holes in crimps |
Hi Perry,
The construction standards that you should have on the Zenith disk that you should have is specific that surfaces MUST contact fully at all rivet locations or words to that effect. I expect that Caleb will tell you to re drill the holes that overlap the crimps 10mm away from the offending hole. Caleb may have a good solution as to how to fill the offending holes too
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 4/26/2012 8:29:56 A.M. Mountain Daylight Time, pdelano(at)telus.net writes:
Hi All,
Perry
Posted: Thu Apr 26, 2012 8:44 am Post subject: Elevator Rib, holes in crimps |
Good solution, just make sure that the mating surface contact fully.
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 4/26/2012 10:40:14 A.M. Mountain Daylight Time, twalker(at)cableone.net writes:
| Quote: | I would remove the crimp and put another crimp just to the side. I've never heard of edge distance from a crimp.
Tommy Walker
Hi All,
Perry
ist href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
s.matronics.com/">http://forums.matronics.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Thu Apr 26, 2012 11:10 am Post subject: Elevator Rib, holes in crimps |
Hi Tommy,
Caleb suggested the same idea. Just shift the crimp.
Perry
