Malcolmbru(at)aol.com Guest
Posted: Tue May 30, 2006 5:39 pm Post subject: 582 radiator |
I need a larger radiator to replace the one from my 532 set up I know the
size of the one I got
my radiator size is
4 in hi
1 7/8 thick
18 in of fins
8 lines + top and bottom plate
7/16 in apart on center 3/32 thick (aprox)
hoses in and out on top end 90% 1in dia.
tank ends are 1in
the bolts to hold it on the plane are 20 in apart 1 5/16 oc
3/4 in off set down
I hope this helps call (989) 631-9506 H
(989)233-5377 C Malcolm Michigan
