OS Wig-Wag Project
PostPosted: Wed Apr 18, 2012 8:42 am    Post subject: OS Wig-Wag Project Reply with quote
I'm ready to lift the lid on my contribution
to date. The data package is available at:
http://tinyurl.com/7885bd6
Anyone who enjoys . . . and is capable of sifting
the drawings through the sieve of logical
agreement between the data points is welcome
to do so. Critical review welcomed.
I've included a couple of LEDs on the board
that will emulate the fixtures in the airplane.
This will allow any software developers to
hook a switch and 12v power supply to the board
and exercise the fruits of their efforts
on the bench.
I'll take another pass at the 'sieve' tomorrow
and maybe get some boards on order. I have all
the parts.
gregmchugh
PostPosted: Thu Apr 19, 2012 6:28 am    Post subject: Re: OS Wig-Wag Project Reply with quote
Bob,
Looks good for what I would need for a wig-wag...
Here are some possible typos I think I picked up...
On page 2 the processor part number is listed wrong.
On page 3 at the top right I think that it should read P-1, not P-11.
On page 3 Pin 6 of the micro is being used as GP1 in this application.
On page 3 Pin 7 of the micro is being used as GP0 in this application.
and a couple of questions...
1. Pin 12 on the d-sub connector seems to be unused but also shown
differently than the other pins on the page 1 drawings. Is this
a convention of some sort?
2. Looking at the PIC12F683 data sheet there are some confusing
instructions on using MCLR with Power on Reset but I think that
Pin 4 could be left unconnected for this application or
used for another purpose since there is no external reset circuit.
What is your reading on this?
3. Not sure how much real estate is left on the board but with Pin
4 freed up and Pin 3 unused you might be able to add the Under Voltage
module functions into this module. Connect one pin as an A/D to
read the bus voltage and use the other pin to drive the warning
LED using a spare d-sub pin. Maybe also figure out how to handle
the relay control for the aux battery. Maybe this is something for
the next spin of the board...
As it is, it meets my needs for a wig-wag module but I can see a software
option that might be useful for users with other configurations of lights.
In my case I have two landing lights on the wing and really only need
to have them both off, both on, or the wig-wag. If other users have
a Taxi light and a Landing light they may want to be able to have
an alternate control function that allows: All Off, Taxi On, All On, &
Wig-Wag (or some variation of four different states). Changing the
function of the switch as shown to handle Off, Taxi, All On and then
adding a second switch to ground both inputs for Wig-Wag would
allow this to be done with only a software change needed to implement
in the module. An option for those who would want it...
It may be little early to be looking at Version 2 of the module but I will
throw out a couple of items that might be useful to consider that require
more than a minor spin on the board.
1. Allow for drop in of a PICAxe 8 pin module. This would require
realigning Pin 2 and Pin 7 to handle the Serial In and Out for the PICAxe
configuration and moving the current functions to other pins. Two resistors
are the only added components for the PICAxe serial I/O circuit. Pin 7
can be reconfigured as a regular I/O pin in the application or left
to handle Serial Out (maybe to a remote display?). With Pin 2 and
Pin 7 brought out to the d-sub you would have the capability to
connect to the PICAxe tools and do serial communication with the chip
in the application via the d-sub.
2. In-Circuit Programming of the PIC is something that might be useful
when using the standard PIC chip. Not sure about the need for it...
3. As I noted above, an easy add-on for the current module would
appear to be the functions handled by the Under Voltage module
(warning light and aux battery control).
I expect that others have already come up with more ideas for
using the module. With digital I/O, analog inputs, and a serial
interface there a lots of possible functions for the module even with
only an 8 pin micro.
Lots of options, which is good...
I will be continuing work on a software version to handle the
basic wig-wag function in the next few days. Should have
an initial version available within a week or so.
Greg McHugh
PostPosted: Thu Apr 19, 2012 6:46 am    Post subject: OS Wig-Wag Project Reply with quote
the parts.
Some background on the decisions that went
into satisfaction of design goals:
I started with the following ideas for
crafting the configuration I published:
1. Use the already developed package based
on Polycase enclosure and D15 connector. I
have cases and lids already cut to accept the
connector. Of course, this sets the boundaries
on the ECB.
2. Use simple on-off-on toggle switch to achieve
OFF-WW-ON control functionality. Easily handled
with software logic.
3. Minimum parts count.
4. Minimum variety of parts.
5. Maximize heat-sink copper for the FETs
6. Add some functional indictors for
as-development tools (a couple of LEDs)
so that bench testing of software needs only
a switch and power supply.
Parts selection was pretty easy. As one
can see from the schematic, all resistors
and capacitors are the same value. This
makes it easier to order, stock, and
install with minimized error. The only
parts that required any "calculation for
performance" was the voltage divider for
the power supply (exact value not critical
and they only needed to be equal). And
the series resistor for the shunt regulator.
The calculated optimum value could be achieved
by paralleling 4 of the common bill of materials
value. 4.99K / 4 gives us about 1200 ohms
at better than 1 watt because the heat doesn't
come out of a single device . . . but is spread
over larger area.
The other values go to transient immunity.
Two standard practice bypass capacitors on supply
rails, two capacitors and two transorbs
protecting fragile silicon from stuff conducted in
on the ship's wiring.
This is a good example of what my cohorts
at HBC called a "cotton ball" . . . very
non-critical components (tells us that
drifts in performance due to component
tolerance/drift are insignificant). The
thought processes that go toward component
selection are pretty ho-hum.
Not to take away from the ultimate
functionality of the assembly. Once the
silicon is safely wrapped in environmental
cotton, the magic poured into the source
code is relatively unrestricted.
A similar philosophy was adopted for the
'do-lots' board from which this project
evolved. Figure out a way to wrap an 8-pin
PIC up in a deep sea diving suit and then
teach it how to sing, dance and do dishes.
I'll order boards today. As Eric mentioned,
ExpressPCB doesn't fuss about what is on a
miniboard (3 pieces returned in 3 days for
$70). Each mini-board will give us two
finished boards with a couple of avionics
ground bus boards thrown in on the side . . .
sorta like this:
[img]cid:.0[/img]
So we'll end up with 6 boards for the development
work at a cost of just over $11 each and turned
around in 3 days. If I sell some avionics grounds
with the 'residuals' then the out-of-pocket development
costs go down.
Folks interested in doing software for this
project need to chime up. I'll provide an
assembled board with a control switch attached.
You'll need a 12v source (2 el-cheapo WalMart
lantern batteries?) and a development system
of your choice. I'll throw in a couple of
PIC chips and install a socket on the board
for ease of swapping the chip between programmer
and the end product demonstration.
It's my vision for this project to publish all
the drawings, ECB source files, and software
sources which anyone can use to carry this
project (or perhaps another functionality on
the same hardware) forward. Of course, most
individuals accessing this data have no interest
in evolving/building their own. But this could
lay the ground work for others to cultivate
their own ideas for other products in a garden
we've already planted with expertise contributed
from a family of participants.
That's what Open Source is all about . . .
 Filesize:  121.61 KB
 Viewed:  14334 Time(s)
enginerdy(at)gmail.com
PostPosted: Thu Apr 19, 2012 7:31 am    Post subject: OS Wig-Wag Project Reply with quote
In that case, maybe consider dropping a Open Source Hardware logo in the copper...
http://freedomdefined.org/OSHW
http://oshwlogo.com/
PostPosted: Thu Apr 19, 2012 8:11 am    Post subject: OS Wig-Wag Project Reply with quote
Interesting! Hadn't seen that before. I'm
not ExpressPCB has a feature that would
allow us to craft that exact symbology
onto the board . . . but certainly documents
that accompany the package could included
it. I'll see what I can do.
Bob . . . [quote][b]
PostPosted: Thu Apr 19, 2012 8:14 am    Post subject: OS Wig-Wag Project Reply with quote
At 09:28 AM 4/19/2012, you wrote:
Good input. Give me a day or so to get the disagreements
sifted and consider the broader options.
PostPosted: Fri Apr 20, 2012 10:49 am    Post subject: OS Wig-Wag Project Reply with quote
--> AeroElectric-List message posted by: "gregmchugh" <gregmchugh(at)aol.com>
Bob,
Yeah, I had a number of loose ends dangling out. I've
updated the data package with more organized Bill of Materials
and some expanded information.
http://tinyurl.com/6lh769o
Fixed that.
Yes, when configured for reset input, there's a built in pull up resistor . . . if we left that pin un-used, then the programmer could set that pin's function to serve as a reset with no connection and no pull-up needed. However, the next iteration of the design uses pin 4 as an general purpose input so the pull up is needed,
[img]cid:.0[/img]
Your suggestion sparked some consideration of making this board capable of doing the functions presently proposed for the 9024 4-function module.
By removing two pull-ups 11 and 14 and adding two divider resistors 26 and 27, these inputs can be shifted from discrete commands to analog inputs. By taking pins 4 and 3 out to the d-sub connector, the user selection of functionality can be accomplished the jumpers in the plug.
I've added another dash number to the ECB assembly to reflect this potential. I'll suggest we leave the 4-function module on the back-burner until the current wig-wag design is gelled . . . but I'm considering putting the 4-function module into the Open Source program too. It would be nice to get that product into the catalogs and this seems like the shortest path to that goal. As it is, it meets my needs for a wig-wag module but I can see a software
I considered that . . . but consider that the target system is LED replacements for incandescent lamps with larger demands. There doesn't seem to be much value in being able to select individual landing/taxi lights. Having both on when using benefits of one didn't seem to be much of a feature.
I looked into using 2 and 7 as program select pins instead of 5 and 4. Problem is that pin 5 could substitute for pin 7 because they both have GP i/o and A/D. However, 4 cannot interchange with 2 because it doesn't offer any output. A PICAXE compatible version could be crafted if we gave up one of the HexFets.
Yup, I think the P2 version of the data package will accommodate that idea.
Okay, peek at P2. I've got some work to do in Wichita this weekend. I'll take a copy to pray over with a target for ordering boards on Monday
 Filesize:  27.56 KB
 Viewed:  14308 Time(s)
gregmchugh
PostPosted: Sun Apr 22, 2012 6:33 am    Post subject: Re: OS Wig-Wag Project Reply with quote
Bob,
Took a look at the P2 version and it looks good. Only noticed an issue
on page 3 with the d-sub pins. Pin 11 is listed twice (one should be
Pin 10) and Pin 2 is missing (2nd line to the power bus).
I will use the P2 to continue with the software for the wig-wag. I should
have something available later this week to use for testing with the
hardware.
Greg McHugh
PostPosted: Mon Apr 23, 2012 6:07 am    Post subject: OS Wig-Wag Project Reply with quote
At 09:33 AM 4/22/2012, you wrote:
Bob,
hardware.
Very good. I'll order boards today when I get back
to the office. Been toting barges and lifting bales
this weekend (moving furniture).
PostPosted: Fri May 04, 2012 9:19 am    Post subject: OS Wig-Wag Project Reply with quote
The boards are here and I've stuffed some of the
parts. Thought I'd ordered the IRF6201 hex-fets
but that slipped under the rug. Those are on order
and should be here Monday. May have the development
articles ready to mail then.
How many folks are herding bytes for this board
configuration and need hardware? I need mailing
addresses.
gregmchugh
PostPosted: Fri May 04, 2012 9:50 am    Post subject: Re: OS Wig-Wag Project Reply with quote
Bob,
Send one out to me, please...
I will test the current software and if it checks out I will flash some
PIC12F683 chips and send them out to you. If there is anyone else
who is getting one of the initial boards and would like a flashed
micro let me know.
Greg McHugh
4201 N Willoway Estates Ct
Bloomfield Hills, MI 48302
FisherPaulA(at)johndeere.
PostPosted: Tue May 08, 2012 12:57 pm    Post subject: OS Wig-Wag Project Reply with quote
Bob,
I'd like one of the boards. I'm not sure if I'll be herding bytes, or they will be herding me, but I'd like to try! Please let me know what I owe you for it.
Greg - as long as I've got your code, I'll try to flash my own chip... but I'll contact you if I can't get it to work!! Wink
Thank you!!
Paul A. Fisher
8428 114th Avenue West
Taylor Ridge, Illinois 61284
