Control wheel refurb
mbcrisp
PostPosted: Mon Apr 16, 2012 3:39 pm    Post subject: Control wheel refurb Reply with quote
Does anyone have any suggestions on where to get control wheels refurbished? My control wheels are starting to peel and look pretty bad. I have seen several options such as leather covers but wondered if anyone has found a solution that really looks good. Also, has anyone ever replaced the lower plastic panel where the the rocker switches and throttle are located? How labor intensive is it to replace? Mine is beginning to look really bad and has several cracks.
n26390(at)AOL.COM
PostPosted: Mon Apr 16, 2012 3:46 pm    Post subject: Control wheel refurb Reply with quote
Trade-A-Plane usually identifies folks that do refurbishing.
Roger Rucker
AA5A '78 HWO
teamgrumman(at)yahoo.com
PostPosted: Mon Apr 16, 2012 10:44 pm    Post subject: Control wheel refurb Reply with quote
I have "refurbished" a lot of yokes. In the process, I drill them for built in PTT. They look very professional. AND . . . No visible wires. It's time consuming and expensive. Figure about $320 delivered.
I strip them, sand blast them, have them chem-film plated, drilled, powder coated, and wired with PTT buttons and shielded 2-wire twisted pair.
I've powder coated with gloss black, satin black, black wrinkle, black and gold hammertone, black and silver hammertone, and dark gray wrinkle. I've also had the yoke shaft powder coated with satin black. The black yoke shaft looks really cool with the powder coated yokes.
Gary
http://forums.matronics.com/viewtopic.php?p=371000#371000
jwellum(at)AOL.COM
PostPosted: Tue Apr 17, 2012 5:51 am    Post subject: Control wheel refurb Reply with quote
I powder coated mine a charcoal gray that has a greenish tint that matches the interior of our 79 Tiger. The original coating came off easy and I was surprised by how rough the control wheel castings were under the original coating. I smoothed them out and applied more powder than usual to help fill in the imperfections. They turned out nice but some of the pits in the original casting can be seen if you look close.
In a message dated 4/16/2012 6:40:25 P.M. Central Daylight Time, mbcrisp87(at)gmail.com writes:
--> TeamGrumman-List message posted by: "mbcrisp" <mbcrisp87(at)gmail.com>
PostPosted: Tue Apr 17, 2012 8:43 am    Post subject: Control wheel refurb Reply with quote
Here is Bill Kelly's plane.
To: "teamgrumman-list(at)matronics.com" <teamgrumman-list(at)matronics.com>
Sent: Monday, April 16, 2012 11:44 PM
Subject: Re: Control wheel refurb
--> TeamGrumman-List message posted by: Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)>
Gary
On Apr 16, 2012, at 4:39 PM, "mbcrisp" <mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com)> wrote:
--> TeamGrumman-List message posted by: "mbcrisp" <mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com)>
bsp; --> http://www.matronics.com/Navigator?TeamGrumman-List========================<brte ; &nb======================
 Filesize:  455.62 KB
 Viewed:  11216 Time(s)
michael(at)flightsked.com
PostPosted: Tue Apr 17, 2012 2:28 pm    Post subject: Control wheel refurb Reply with quote
I have a set of Gary's yokes in my Tiger, and they look so much better than the originals. Nice and clean, no wires hanging out by your leg for the PTT.
http://www.aucountry.com/index.html
He put them in several years ago, and they still look pretty much new.
Michael
Michael W. Meyer
Tiger N74086
San Francisco, CA
michael(at)flightsked.com (michael(at)flightsked.com)
On Apr 16, 2012, at 11:44 PM, Gary L Vogt wrote:
[quote]--> TeamGrumman-List message posted by: Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)>
Gary
[quote]--> TeamGrumman-List message posted by: "mbcrisp" <mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com)>
http://www.matronics.com/co=================
mbcrisp
PostPosted: Tue Apr 17, 2012 2:52 pm    Post subject: Re: Control wheel refurb Reply with quote
How are the wires run? Are they run through the shaft? Also, is that $320 each or for the pair to refurbish?
PostPosted: Tue Apr 17, 2012 6:10 pm    Post subject: Control wheel refurb Reply with quote
Mike, call me.
Sent: Tuesday, April 17, 2012 3:28 PM
Michael
Michael W. Meyer
Tiger N74086
San Francisco, CA
Gary
http://www.ma &n   -     &nbs --> http://www.matronics.com/co=================
[quote]http://www.matronics.c====
PostPosted: Tue Apr 17, 2012 6:31 pm    Post subject: Control wheel refurb Reply with quote
$320 for the pair. Wires inside.
Sent: Tuesday, April 17, 2012 3:52 PM
http://forums.matronics.com/viewtopic.php?p=371102#371102
mbcrisp
PostPosted: Tue Apr 24, 2012 6:43 am    Post subject: Re: Control wheel refurb Reply with quote
Anyone ever purchase/install leather yoke covers from Warren Gregoire? They seem pretty nice. You can even get the PTT built in if you like.
http://www.warrengregoire.com/aviation-leathercontrolyokecovers.htm
Scroll about 3/5 the way down and you will see the grumman yokes.
PostPosted: Tue Apr 24, 2012 10:36 am    Post subject: Control wheel refurb Reply with quote
the buttons are cheesy. they get ragged and worn looking. Lots of people do cheap. it looks cheap.
Sent: Tuesday, April 24, 2012 7:43 AM
http://forums.matronics.com/viewtopic.php?p=3ch much Navigator?TeamGrumman-List" target="_blank">http://www.matronics.com/Navi======================== [quote][b]
BARRY CHECK 6
PostPosted: Tue Apr 24, 2012 1:05 pm    Post subject: Control wheel refurb Reply with quote
Gary:
How would you want or how SHOULD the yokes be delivered, removed from the shaft or would you want them on the shaft?
And if removed from the shaft how does one re-install the yoke and rivet?
Barry
On Tue, Apr 17, 2012 at 10:31 PM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote]$320 for the pair.  Wires inside.
From: mbcrisp <mbcrisp87(at)gmail.com (mbcrisp87(at)gmail.com)>
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Subject: TeamGrumman-List: Re: Control wheel refurb
http://www.matronics.com/Navigator?TeamGrumman-List<========================
st" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
PostPosted: Tue Apr 24, 2012 3:35 pm    Post subject: Control wheel refurb Reply with quote
I reinstall the yoke with a bolt. They can be delivered either with or without the shaft attached.
Sent: Tuesday, April 24, 2012 2:03 PM
Subject: Re: Re: Control wheel refurb
Gary:
Barry
garnerrice(at)hotmail.com
PostPosted: Thu Apr 26, 2012 4:02 am    Post subject: Control wheel refurb Reply with quote
