bjudge(at)gmail.com Guest
Posted: Mon Apr 16, 2012 5:42 am Post subject: Vans standard fuel selector valve overhaul |
Greetings,Has anyone on the list overhauled a vans standard fuel selector valve?
If you have I've got a few questions:
How empty do the fuel tanks have to be?
Is EZ-Turn Fuel lube the right stuff to use?
Any gotcha's I should worry about?
Bill Judge
N84WJ, RV-8, 732 hrs
http://rv-8.blogspot.com/
JohnF
Posted: Mon Apr 16, 2012 8:16 am Post subject: Vans standard fuel selector valve overhaul |
Bill, I had, but sold, an RV6A that once had a standard Van's fuel selector - the brass one - I had replaced it with a fancier one and still have the original laying on a shelf in the hangar...its yours for the cost of mailing it to you if you want it.
John at Salida, CO
n29cx(at)ridgeviewtel.us
[quote] | Quote: |
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
Kellym
Posted: Tue Apr 17, 2012 5:00 am Post subject: Vans standard fuel selector valve overhaul |
Well, I had a certified valve on a Cessna that went 40 years before it
needed service, and only took new o-rings to fix. I have a 47 year old
valve with over 6000 hours on a Mooney that hasn't needed service yet.
So yes, there is a difference in quality between what Van's supplies and
real quality.
Kelly
RV-10 with Andair, "finishing"
On 4/17/2012 4:06 AM, Bill Judge wrote:
| Quote: | J
I'm always amazed how everyone uses the really expensive and much
harder to install Andair valve when the standard Vans one works just
fine... Well, mine is a little stiff after more than 5 years and 730
hrs...
Bill
Checked by AVG - www.avg.com
KCHD |
denis.walsh(at)comcast.ne Guest
Posted: Tue Apr 17, 2012 7:27 am Post subject: Vans standard fuel selector valve overhaul |
I removed my (standard Van's) fuel valve a year or so ago and replaced it. It was leaking around the stem a bit after 14 years of hard service. I felt it was entitled to be replaced.
After I went to all that aggravation and toil, with good success, I did an autopsy on the old valve, and learned I could have easily just removed the guts without taking out the whole thing. I can't remember for sure but there is probably an o ring on that stem, and some lube would have fixed it.
HOWEVER. I do recall that there was a previous version of this valve which had a brass innerd instead of the present nylon one. That thing had a tendency to jamb after a few years and scared the crap out of a few people when they were unable to switch tanks in flight.
SO when you remove it, check to see if it is brass or nylon. The nylon ones still get a little stiff but don't jam like the old ones. I would consider changing it if it is the old brass type.
Lastly: If you don't fly very often, I would make a check list item to make sure you switch tanks before take off to insure it is not jammed!
Denis Walsh
denis.walsh(at)comcast.net (denis.walsh(at)comcast.net)
On Apr 17, 2012, at 5:06 , Bill Judge wrote:
[quote]John,
Thanks for the offer! I can re lube the selector with out having to remove it so I'll just do that. Half of what I'm trying to avoid is removing the valve because it's in such an awkward spot to work on. I'll just remove the gland nut and re lube and put it back in.
Vans reports that EZ turn is the lube to use.
Still, I guess I'll just slide the valve stem out a bit and see if my tanks are empty enough.
I'm always amazed how everyone uses the really expensive and much harder to install Andair valve when the standard Vans one works just fine... Well, mine is a little stiff after more than 5 years and 730 hrs...
Bill
Time: 09:16:05 AM PST US
From: "John Fasching" <n29cx(at)ridgeviewtel.us (n29cx(at)ridgeviewtel.us)>
Subject: Re: Vans standard fuel selector valve overhaul
John at Salida, CO
Bill JudgeN84WJ, RV-8, 732 hrshttp://rv-8.blogspot.com/
| [b]
BGray(at)glasair.org Guest
Posted: Tue Apr 17, 2012 7:48 am Post subject: Vans standard fuel selector valve overhaul |
Please, do not switch tanks just before take-off. If there is any problem with feeding fuel from the new selected tank, you’ll discover it about 50 above the runway.
Bruce
WWW.Glasair.org
robin(at)PaintTheWeb.com Guest
Posted: Tue Apr 17, 2012 8:13 am Post subject: Vans standard fuel selector valve overhaul |
I had a vans valve on my 6A and was tired of fuel on my hands. I eventually swapped it out for an Andair valve. Wow what a difference. I have had 3 RVs since then all with Andair valves. The top reasons for pilot deaths is WX and Fuel issues. Now granted most likely fuel management not fuel valve but I figure anything one can do to upgrade the fuel system is $ well spent.
Robin
Sent from the new iPad
On Apr 17, 2012, at 9:04 AM, "Bruce" <BGray(at)glasair.org (BGray(at)glasair.org)> wrote:
[quote] <![endif]--> Clean DocumentEmail <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]--> <![endif]--> <![endif]-->
Bruce
WWW.Glasair.org
davemader(at)bresnan.net Guest
Posted: Tue Apr 17, 2012 10:32 am Post subject: Vans standard fuel selector valve overhaul |
I do know Vans changed his standard valve a few years ago. My first valve
from Vans went on my first RV6 in the '90s caused lots of problems, his
later valve I installed on my last RV6 in 2005 has worked well.
ceengland(at)bellsouth.ne Guest
Posted: Tue Apr 17, 2012 11:19 am Post subject: Vans standard fuel selector valve overhaul |
Hi Bill,
If mounting position is similar to the -4, you'll probably be ok at a little under 1/2 tanks. The -8 has longer tanks, so you'll probably need to go a little under 1/2 (which worked on my -4).
If you have a gascolator, & it's lower than your selector valve, just do your draining from there, with a loose fitting near the valve to break any siphon effects.
Charlie
On 04/17/2012 06:06 AM, Bill Judge wrote: [quote] John,
Bill
John at Salida, CO
| Greetings, Has anyone on the list overhauled a vans standard fuel selector valve?
Bill Judge N84WJ, RV-8, 732 hrs http://rv-8.blogspot.com/
Posted: Tue Apr 17, 2012 11:23 am Post subject: Vans standard fuel selector valve overhaul |
And if you had a turbine on either a/c, you wouldn't have had to
overhaul the engine 6 or 8 times, either. Doesn't mean that it would be
a good value on the plane, though.
Charlie
On 04/17/2012 07:59 AM, Kelly McMullen wrote:
and real quality.
Kelly
> J
> hrs...
> Bill
Kellym
Posted: Tue Apr 17, 2012 12:54 pm Post subject: Vans standard fuel selector valve overhaul |
In 6000+ hours my Mooney has had approx 1 overhaul per decade, including
one for gear up landing. As in 4 total over 47 years. Lycoming publishes
12 yrs or 2000 hours to TBO. That is what mine has averaged and as
expected. Fuel valves don't see anywhere near that kind of action, and
shouldn't need more than O-ring replacement once every 10-20 years.
What price do you put on the quality of your fuel valve when you have a
couple gallons in one tank and 20-30 in the other tank not selected with
no airport within 100nm?
On 4/17/2012 12:23 PM, Charlie England wrote:
be a good value on the plane, though.
Charlie
KCHD |
