1mitchkelly(at)comcast.ne Guest
Posted: Sun Apr 15, 2012 12:31 pm Post subject: Magneto grounding |
I have Slick 4301 magnetos and ACS A-510-2K ignition / starter switch. Operation is normal, however when I measure resistance between p-lead (either mag) and ground with switch set to Both, it reads zero. This is not what I expected, what am I missing?
Mitch
john.maccallum(at)bigpond Guest
Posted: Sun Apr 15, 2012 12:53 pm Post subject: Magneto grounding |
That is correct Mitch, the Mag P leads are open circuit on both. If you put the switch to Left the Right P lead will show a short to ground
and the Left will be open circuit. Then if you reverse it and switch to the Right Mag  the Left will be grounded.
Cheers
John MacCallum
VH-DUU
RV 10 #41016
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of 1mitchkelly(at)comcast.net
Sent: Monday, 16 April 2012 6:26 AM
Subject: Magneto grounding
Mitch
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234567
Posted: Sun Apr 15, 2012 1:13 pm Post subject: Magneto grounding |
On 04/15/2012 03:25 PM, 1mitchkelly(at)comcast.net (1mitchkelly(at)comcast.net) wrote: | Quote: | p { margin: 0; }
Mitch
| What you're seeing is a normal reading. With the mag switch 'on' (so the mag can operate), you are reading the DC resistance of the magneto coil primary winding, which is so close to zero that a regular ohm meter can't read it accurately. It will look like a dead short. The *impedance* (in quick & dirty terms, the AC resistance) is higher, but your ohm meter can't measure that. This is the reason for 'buzz boxes', used to set the timing of magnetos. They generate an AC signal that's fed into the mag, and can detect the difference between reading across the coil or seeing a truly dead short, when the points inside the mag are closed (or your mag switch is set to 'off').
Hope that helps,
Posted: Sun Apr 15, 2012 1:43 pm Post subject: Magneto grounding |
At 03:48 PM 4/15/2012, you wrote:
| Quote: | That is correct Mitch, the Mag P leads are open circuit on both. If you put the switch to Left the Right P lead will show a short to ground
and the Left will be open circuit. Then if you reverse it and switch to the Right Mag  the Left will be grounded. |
It's a bit more complex than that.
A magneto has a core of magnetic material which
can be 'excited' by a rotating magnet rotated on
a shaft. One winding has many turns of very fine
wire in which converts the rapidly changing
magnetic flux from the rotating core magnet
to a high voltage pulse (4-8,000 volts). This
pulse is routed through a distributor to the
appropriate plug wire to cause a spark across
the plug's gap in the cylinder.
A second winding of very few turns of heavy wire
is connected to the magneto's interrupter 'points'.
The schematic of this arrangement is shown here:
[img]cid:.0[/img]
As long as the points are closed, a dead short
exists across the primary winding and the rate of
rise of magnetic flux within the core is retarded.
As the points open, that retarding force is suddenly
removed allowing the high voltage to be generated
and distributed to the appropriate plug. Setting
the position of this 'opening event' with respect
to crankshaft and piston position is accomplished
in a "timing procedure".
The primary winding has VERY low dc resistance.
So when you measure the resistance on a magneto's
p-lead to ground, it is difficult if not impossible
to detect when the points open as the shaft is
rotated.
This is why magneto "timing lights" have little
buzzers or electronic oscillators inside to generate
an AC excitation signal which sees a much larger
AC impedance jump as the points open.
http://tinyurl.com/6ttzr94
Shower-of-Sparks ignition systems excite the primary
still more strongly and repetitively during cranking
to generate a stream of sparks when the points open.
http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf
But unless your measurement system for resistance has
resolution in the milliohms range . . . like this
one . . .
http://tinyurl.com/6o5kqub
You won't be able to use an ohmmeter to either measure
the primary coil resistance -OR- detect a open/close
event on the magneto's points.
26.14 KB |
2895 Time(s) |
