poasttown(at)yahoo.com Guest
Posted: Thu Mar 22, 2012 4:29 pm Post subject: Balance Tires |
I have always balanced my tires and rims when I install new tires. However, when I mentioned this to a few pilots flying non-experimental aircraft (Cessena 150) they said they didn't balance their tires.
What is the standard out there?
Mike Chaney
1996 Kitfox IV
Jabiru 2200
Roger Lee
Posted: Thu Mar 22, 2012 5:10 pm Post subject: Re: Balance Tires |
Hi Mike,
I balance all my customers tires and every single tire needs it.
You are wise to balance them. I never see tires that are balanced right after they are mounted without weights. Out of balance tires can cause a lot of plane shake. It's too easy to do to not do it.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Float Flyr
Posted: Thu Mar 22, 2012 6:06 pm Post subject: Balance Tires |
If you have a tire that weighs several hundred pounds and runs down the runway at better than a hundred miles an hour then I would say it better be balanced. A $1.50 probably will never make it to 80 mph on the ground but I bet they still have the marker for the tire valve on them
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Mike Chaney
Sent: March 22, 2012 9:58 PM
To: kitfox
Subject: Balance Tires
Mike Chaney
1996 Kitfox IV
Jabiru 2200
| Quote: | | < - The Kitfox-List Email Forum Use the Matronics List Features Navigator to browsehttp://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.com | 0123456
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Fri Mar 23, 2012 5:28 am Post subject: Re: Balance Tires |
Certified tires will be marked with a red dot/line at the lightest point. You simply match that up with the valve stem on the tube to get close. After that, aircraft tires are generally considered to be self-balancing; The heaviest part of the tire falls to the bottom of the wheel in flight, and gets rubbed off when the wheel touches the pavement.
Now for those of us using off the shelf ATV tires and/or flying 90% off of sod/dirt, it is a good idea to balance them. Those tires won't be held to the same tolerances and grass won't "balance" the tires for you.
_________________ Kitfox IV-1200
Indianapolis, IN |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Mar 23, 2012 6:47 am Post subject: Balance Tires |
I'm probably missing something here, but with the exception of a little
vibration after immediate lift off, which can be handled with a brief touch
of the brakes, what risks am I incurring by not balancing my tires?
Lowell
Sent: Friday, March 23, 2012 6:28 AM
Subject: Re: Balance Tires
Ryan Wheeler
Kitfox IV-1200
Indianapolis, IN
http://forums.matronics.com/viewtopic.php?p=369214#369214
rawheels
Posted: Fri Mar 23, 2012 8:49 am Post subject: Re: Balance Tires |
| lcfitt(at)sbcglobal.net wrote: | I'm probably missing something here, but with the exception of a little
of the brakes, what risks am I incurring by not balancing my tires? |
That is a good question. At our speeds there probably isn't much, and the plane is designed to handle bush landings, right?
Float Flyr
Posted: Fri Mar 23, 2012 10:48 am Post subject: Balance Tires |
Lowell: Ever had a car that the weights fell off the tires? Well I have and
vibration occurs somewhere after forty or fifty miles an hour... long after
a Kitfox is up in the air. Some Cessnas and the like land at much higher
speeds and wheel balance will be of more importance to them as their tires
are heavier, turn faster and they don't land hard enough to self balance.
Noel
Kitfox III-A
msm_9949(at)yahoo.com Guest
Posted: Fri Mar 23, 2012 12:07 pm Post subject: Balance Tires |
Then again, there them that tow their Foxes, on the mains, down the road at highway speeds. :-0
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
Hersey, MI
Sent: Friday, March 23, 2012 2:47 PM
Subject: RE: Re: Balance Tires
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)>
Noel
Float Flyr
Posted: Fri Mar 23, 2012 1:14 pm Post subject: Balance Tires |
I didn’t think anybody did that anymore. Something to do with the tires being approved for use on a highway. Then again if the cop doesn’t ask... Don’t tell!
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Marco Menezes
Sent: March 23, 2012 5:37 PM
Subject: Re: Re: Balance Tires
Marco Menezes N99KX
Hersey, MI
From: Noel Loveys <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)>
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Noel
Kitfox III-A
