Wing Cradle Dimensions...
jackinkeywest
PostPosted: Wed Mar 28, 2012 12:34 pm    Post subject: Wing Cradle Dimensions... Reply with quote
Hello fellow 'Kolbers',
I am new to the list (first time posting...). I recently purchased a Kolb Mark III Classic (M3C) that I will have to transport in an enclosed 24' car hauler/trailer to its new home in Key West, FL. The wings have been removed from the plane and I would like to pre-build a wing dolly/cradle to safely hold the wings for the long ride.
Does anyone have drawings or instructions I could build a wing dolly or cradle from?
Thanks in advance,
Jack Lockamy
Key West, FL
Kolb Mark III-C w/582
Ex Co-Owner: Cirrus SR-20
Ex Builder/Owner: RV-7A
Ex Builder/Owner: Sonex TD
Ex Builder/Owner: Sonerai II TD
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  599 Time(s)
Mike Welch
PostPosted: Wed Mar 28, 2012 12:45 pm    Post subject: Wing Cradle Dimensions... Reply with quote
Hi Jack,
You might consider one of these; if this is something you are interested in, let me know and I'll see if
I can come up with some dimensions for you.
BTW, it makes rolling your plane around on your shop floor mighty easy, es[ecially whe you add my handy-dandy
front wheel dollys, too.
Mike Welch
MkIII Xtra wannabe
On Mar 28, 2012, at 3:33 PM, Lockamy, Jack CIV Atlantic Targets Marine Ops, AD.5.3.3 / Key West Det wrote:
Thanks in advance,
Jack Lockamy
Key West, FL
 Filesize:  113.55 KB
 Viewed:  10051 Time(s)
 Filesize:  72.47 KB
jackinkeywest
PostPosted: Wed Mar 28, 2012 12:58 pm    Post subject: Re: Wing Cradle Dimensions... Reply with quote
Hi Mike,
Thanks for the pics and reply. That is a cradle I can definitely use once I get the wings hung again and start transporting the plane to/from the field.
For this first transport, I am looking to build a plywood cradle for the two wings so I can strap them against the wall of the car hauler. I just need the dimensions of the wings so I can make my cut-outs in the plywood and lay down some old carpet or foam for padding against the surfaces. Something cheap, easy to build but sturdy enoughto handle the long ride.
Thanks again!
Jack in Key West
russk50(at)gmail.com
PostPosted: Wed Mar 28, 2012 1:06 pm    Post subject: Wing Cradle Dimensions... Reply with quote
Jack-in-Cayo-Hueso
How long is your 'long ride'?
Just curious
On Mar 28, 2012, at 4:58 PM, jackinkeywest wrote:
Hi Mike,
Thanks again!
Jack in Key West
http://forums.matronics.com/viewtopic.php?p=369489#369489
rlaird
PostPosted: Wed Mar 28, 2012 1:20 pm    Post subject: Wing Cradle Dimensions... Reply with quote
Jack --
When I transport my Kolb long distances, I use broad nylon straps to suspend them from the ceiling of the enclosed trailer I have, and then padded the wings on both sides with moving blankets (and padded the straps from the wing LE with foam rubber).  They made the trip from California to Texas without a problem, and saved me the trouble of constructing cradles.
  -- Robert
On Wed, Mar 28, 2012 at 4:06 PM, kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)> wrote:
[quote] --> Kolb-List message posted by: kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)>
Jack-in-Cayo-Hueso
Just curious
> --> Kolb-List message posted by: "jackinkeywest" <jack.lockamy(at)navy.mil (jack.lockamy(at)navy.mil)>
> Hi Mike,
> Thanks again!
> Jack in Key West
le, List Admin.
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
jackinkeywest
PostPosted: Thu Mar 29, 2012 3:19 am    Post subject: Wing Cradle Dimensions... Reply with quote
Hi Russ,
Ride is approx. 1900 miles (30 HRS) EACH WAY! Key West, FL to Iron Mountain, MI. Once off the Keys Overseas Hwy (US1), it's I-75 north to MI and back...
Will be stopping in ATL on the way up to drop off a set of floats and picking up another set of floats in lower MI on the return South with a quick stop in London, KY to visit the good folks at the Kolb Factory (if they're back from SNF 2012 in Lakeland).
Jack in Key West
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  563 Time(s)
jackinkeywest
PostPosted: Thu Mar 29, 2012 3:21 am    Post subject: Wing Cradle Dimensions... Reply with quote
Robert,
Good idea! I've got plenty straps and moving blankets. Might just be the easiest solution.
Thanks!
Jack in Key West
DO NOT ARCHIVE
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  556 Time(s)
Thom Riddle
PostPosted: Thu Mar 29, 2012 3:34 am    Post subject: Re: Wing Cradle Dimensions... Reply with quote
Russ,
Sorry to say this but your "Google Translate" Spanish is incorrect. Hueso is Spanish for the English word Bone. West in Spanish is Oeste.
do Not Archive this non-kolb related post
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
jackinkeywest
PostPosted: Thu Mar 29, 2012 3:48 am    Post subject: Wing Cradle Dimensions... Reply with quote
A note on the word "Key" used to identify an island. Its origin is not well established except by usage. Most believe that it began by the Spanish adapting the word "cayo' from the Taino Indians of Hispanola and Cuba referring to small islands. The Spanish normally used "isla" for island and "islet" for small island. At least in the New World, they appear to use "cayo" and "cayuelo" for a very small island. The English used "Cay" or "Kay" such as Cay Sal Banks. Cay is pronounced by Americans as the letter "K," but by Englishmen as the word 'Key.' I am not certain if the written and the pronounced versions made any difference. Anyway, English maps of the Keys made just prior to the Revolutionary War of 1776 used the word "Key." A Colonial American court record of the "Libel of Dennis and Allen vs the snow St. Fermin alias Britanis" in 1744 used the word "Keys" referring to the Florida Keys. This is one case where an American court reporter might write ''Key' when an Englishmen
prounced 'Cay.' See the Admiralty Papers, Vol. 2, 1743 -1744.
Jack in Key West
DO NOT ARCHIVE
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  616 Time(s)
russkinne(at)mac.com
PostPosted: Thu Mar 29, 2012 4:01 pm    Post subject: Wing Cradle Dimensions... Reply with quote
Thom
Sorry to say but the key was named for the large amounts of bones there. It's Cayo Hueso, nothing to do with west -- except in English.
I don't need Google to translate for me.
On Mar 29, 2012, at 7:34 AM, Thom Riddle wrote:
Russ,
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
Truth is what stands the test of experience.
- Albert Einstein
http://forums.matronics.com/viewtopic.php?p=369520#369520
Watkinsdw
PostPosted: Sun Apr 08, 2012 1:42 pm    Post subject: Re: Wing Cradle Dimensions... Reply with quote
Hi, Jack,
I suppose the NSA will flag my salutation...
but I'm innocent, live in Deerfield Beach, FL, and will be
in Key West next week for a little R&R with the family.
Maybe we can meet. I'd like to see your Mk3.
I'll bring pics of mine.
Dave Watkins
2001 Mk3 Classic
Just flew to S&F for the first time.
