rowlandcarson(at)gmail.co Guest
Posted: Sat Mar 24, 2012 1:34 pm Post subject: TS05 retention query |
I seem to recall that someone on this forum mentioned adding small lightweight discs near the ends of the TS05 cross-piece, inside the fuselage. This had the dual effect of keeping the TS05 from moving sideways while rigging and de-rigging (reinforcing that provided by the ply pieces called out in the manual) and also improving the cosmetic appearance of the slot in which TS05 operates.
I've searched the back postings using various keywords that I thought likely but can't turn up what I'm looking for.
Would the original poster (or someone who remembers the posting) please help me find it? Date of the post, who made it, or a copy of the original would all be very acceptable.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
steven.pitt2(at)ntlworld. Guest
Posted: Sat Mar 24, 2012 11:20 pm Post subject: TS05 retention query |
Rowland - I tried to take some pictures this morning but could not get the
right resolution to help with your enquiry.
However, I checked my aircraft and can see that I cut a piece of plywood
(possibly about a foot long) and fibregalssed it onto the inside of the tail
on either side of the vertical surfaces, forward of and level with the top
of the trimtube slots. I then cut a 'u' shape slot between them to allow the
trim tube to move up and down but restricted the side to side movement.
This version means that the side slots remain open but also means that the
TS05 is not altered which might lead to jamming if the discs were to move.
I hope this helps.
Steve
craigb(at)onthenet.com.au Guest
Posted: Sun Mar 25, 2012 12:26 am Post subject: TS05 retention query |
I believe the factory jumped in on this one a few years ago, and warned
against such
A mod, I believe they were concerned with icing etc jamming up the trim
system, and thus
Compromising the flight performance.
I may be wrong however
craig
g-iani(at)ntlworld.com Guest
Posted: Sun Mar 25, 2012 12:31 am Post subject: TS05 retention query |
Roland
I remember the posting but have no record of it
I did the attached drawing for someone who, in effect, asked the same
question. I will get it into the web site soon
Ian
TS05_retraint.pdf |
5.08 KB |
413 Time(s) |
roddyeuropa(at)aol.com Guest
Posted: Sun Mar 25, 2012 12:48 am Post subject: TS05 retention query |
to add, this is not an area of rigging which (in my experience) I have ever had any problems,including rigging single handed. Technique I use is to fully put on one tailplane, (starbord), attach the ts05 to lug on that side, then put on the port tailplane to within about 1/4 inch of fully in, put the ts05 tube half into the lug on the port side, so the tube is now half in the lugs on both sides, and then push the port tailplane fully home.
Roddy Kesterton G-KRK
frans(at)privatepilots.nl Guest
Posted: Sun Mar 25, 2012 1:17 am Post subject: TS05 retention query |
On 03/25/2012 10:47 AM, roddyeuropa(at)aol.com wrote:
| Quote: | to add, this is not an area of rigging which (in my experience) I have
I rig and derig the airplane for every flight and I follow the very same
procedure as described by Roddy. It is no problem at all. I always rig
the tailplanes without any help (my wife has another task during that
stage of rigging). I can't imagine how changes to the TS05 guidance
could make the procedure easier: you still have to guide the TS05 to the
lug. And the sideways play of the TS05 actually helps as you can now
separate inserting the TS05 from aligning the tailplane on the torque
tube. If the TS05 could not move sideways you have to aligh everything
at the same moment which would make it much more complicated.
Furthermore my feeling is that this is a "no-mess" area. Anything put
there might break loose and jam the tailplane and trim, which I'm sure
is no fun flying. What isn't there can't break loose. Just keep it
simple here.
Frans
fklein(at)orcasonline.com Guest
Posted: Sun Mar 25, 2012 2:09 pm Post subject: TS05 retention query |
On Mar 24, 2012, at 2:33 PM, Rowland Carson wrote:
| Quote: | I seem to recall that someone on this forum mentioned adding small
fuselage.
Rowland...I may have been the culprit...but in due course I abandoned
the notion in order NOT to add a potential glitch to pitch control.
I ended up building a little foam box with a screened slot which
centers TS05 and (hopefully) keeps the birds and insects from
venturing into the tailcone...here are a couple of pixs:
Best,
Fred
50.55 KB |
4050 Time(s) |
68.4 KB |
4050 Time(s) |
