Fill-Rite Refueler
Dennis Thate
PostPosted: Fri Mar 23, 2012 11:34 am    Post subject: Fill-Rite Refueler Reply with quote
After a strong endorsement from my local FBO, I decided on this cast iron hand pump lightweight re fueler from a local farm store where replacement parts are readily available, if needed. About $130.
Nex Step : to increase the safety of my refueler would be a ground cable attached to my fuel pump and to my engine block.
Safe Flying All, and keep the water out of your gasoline.
 Filesize:  86.91 KB
 Viewed:  1970 Time(s)
 Filesize:  60.41 KB
 Filesize:  35.96 KB
pc.king(at)comcast.net
PostPosted: Fri Mar 23, 2012 11:48 am    Post subject: Fill-Rite Refueler Reply with quote
And which cast iron hand pump lightweight refueler did you buy?
