EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Tue Sep 18, 2012 3:02 pm Post subject: Jam nuts for wing tie-down eyebolts? |
I'm getting close to finishing up the wing leading edges, and I need to drill out the holes for the wing tie-downs. I have two options... drill it out to 3/8 (plus some breathing room) for just the tie-down bolt, or 11/16 so I can pass a jam nut tight to the tapped aluminum.
Opinions?
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
speckter(at)comcast.net Guest
Posted: Tue Sep 18, 2012 4:11 pm Post subject: Jam nuts for wing tie-down eyebolts? |
My plane is hangered most of the time so I take the tiedown rings out most of the time and thus no jam nuts
Gary
Sent: Tuesday, September 18, 2012 6:01:27 PM
Subject: Jam nuts for wing tie-down eyebolts?
Opinions?
Bob Turner
Posted: Tue Sep 18, 2012 4:21 pm Post subject: Re: Jam nuts for wing tie-down eyebolts? |
I too carry mine with me, install as needed. I do this under the delusion that it gains me huge amounts of extra speed (!). OTOH the tail ring is in all the time.
_________________ Bob Turner
RV-10 QB |
larkrv10(at)gmail.com Guest
Posted: Tue Sep 18, 2012 5:21 pm Post subject: Jam nuts for wing tie-down eyebolts? |
Ed, I intend to "lock tite" mine into the tapped AL threads. I also had mine chromed so they are staying in the wing cause they look so good!
Rick
#40956
Southampton, Ont
On Tue, Sep 18, 2012 at 7:01 PM, Ed Kranz <ed.kranz(at)gmail.com (ed.kranz(at)gmail.com)> wrote:
[quote] I'm getting close to finishing up the wing leading edges, and I need to drill out the holes for the wing tie-downs. I have two options... drill it out to 3/8 (plus some breathing room) for just the tie-down bolt, or 11/16 so I can pass a jam nut tight to the tapped aluminum.
Opinions?
tp://forums.matronics.com
| [b]
partner14
Posted: Tue Sep 18, 2012 6:06 pm Post subject: Jam nuts for wing tie-down eyebolts? |
I just gobbbbed on enough teflon tape so they tighten real good.
Don
Sent: Tuesday, September 18, 2012 8:18 PM
Subject: Re: Jam nuts for wing tie-down eyebolts?
Rick
#40956
Southampton, Ont
Opinions?
| avigator?RV10-List" rel="nofollow" target="_blank">http://www.matronics========================
40636 |
Tim Olson
rene(at)felker.com Guest
bwestfall
Posted: Tue Sep 18, 2012 8:37 pm Post subject: Jam nuts for wing tie-down eyebolts? |
I wonder if that is a "Van's approved" speed mod!
Kellym
Posted: Tue Sep 18, 2012 9:42 pm Post subject: Jam nuts for wing tie-down eyebolts? |
I use the tail hook as my rudder trim and even that gives me a bump in performance.
But I install my S/S wing tie down bolts as needed.
Robin
Sent from the new iPad
EdKranz
Posted: Wed Sep 19, 2012 6:23 am Post subject: Jam nuts for wing tie-down eyebolts? |
Thanks everyone! Sounds like I won't need the jam nuts even if I do leave them in... which I probably won't.
On the other hand, I am going to permanently attach my tail tail down. Wouldn't want the rudder fairing taking damage if a tail strike were to happen...
RV10
Finishing
jchang10
Posted: Wed Sep 19, 2012 7:26 am Post subject: Jam nuts for wing tie-down eyebolts? |
i use a jam nut with the aero SS tie down from cleveland tools. i
leave them in. i left the hole as small as possible.
jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
rv10flyer
Posted: Thu Sep 20, 2012 3:38 am Post subject: Re: Jam nuts for wing tie-down eyebolts? |
Mine all had a slight gap between skin and tiedown. You can fill that gap with proseal, use an o-ring and locktite. I just leave my SS eyebolts in all the time. If the gap is not filled you will be puckering the skin upon tightening.
_________________ Wayne G. |
