fritzsch(at)eskimo.com Guest
Posted: Tue Mar 20, 2012 2:47 pm Post subject: Corrugated Tube Question |
I am using Van's corrugated tube in my wings to protect my wiring. I
need to cut holes for the pitot wire and the landing light wires. Is
that normally done with a soldering iron to poke the hole? And should
you insert a rubber grommet to protect the wire through the hole?
Dave
Dave Fritzsche
Professor, Retired
Penn State
Posted: Tue Mar 20, 2012 3:15 pm Post subject: Corrugated Tube Question |
In the 8A I cut a hole I the corrugated tubing to run those wires. After
you finish the wire run use some silicon seal around the hole/wires to
eliminate relative motion - protecting the wires.
For the 10 I used Lowes polyurethane water line tubing for the wire runs.
The tubing is a snug fit in 3/4" holes, very sturdy but light weight, and
big enough for all the wires and even a coax run to the wingtip VOR antenna.
I simply have a 2" or so space where there is not tubing for things such as
pitot heat, auto pilot, and aileron trim.
Carl
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Mar 20, 2012 3:28 pm Post subject: Corrugated Tube Question |
Soldering iron worked great for me. It kind of curls the plastic so I
didn't use grommets or at least I thought they weren't required. I think
the conduit is soft enough not to cut into the wiring insulation.
Sean
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
johngoodman
Posted: Wed Mar 21, 2012 4:23 am Post subject: Re: Corrugated Tube Question |
I just cut a slit in it to fish out the wire, but I'm sure the soldering iron will work as well. If you ever want to buy it in different sizes or colors, you'll find it on the web as "Convoluted Nylon Tubing", or "Nylon Wire Loom." Here is a web site of a major manufacturer of it:
http://www.taylorvertex.com/Products/index.cgi/bulkTubing
