Edwardoc
Joined: 20 Aug 2009 Posts: 8 Location: Kersey, CO 80634
d-burton(at)comcast.net Guest
Posted: Sun Mar 18, 2012 3:08 pm Post subject: Mounting a replacement Tail wheel spring (Tapered Spring) |
If you take the broken spring and the new one to a machinist it should be
trivial for him to match drill the new one for you.
Sent: Sunday, March 18, 2012 3:48 PM
To: <rv-list(at)matronics.com>
Subject: Mounting a replacement Tail wheel spring (Tapered Spring)
Did a quick search and didn't find any other posts about replacing the
tail wheel spring (the tapered spring rod). I had drilled an additional
hole in my spring when I mounted an aftermarket tailwheel and then
enlarged it to an AN4 to get it aligned. I later replaced the tailwheel
with Van's standard unit and the hole was not required. The Rod snapped
at the hole taxing in. My question is "does anyone have any suggestions
on how to drill the new mounting hole in the spring at the base end inside
the fuselage. I need to insert the new spring rod in the steel mounting
fixture (WD 409 I think it is) and then drill a matching hole in the new
spring. I think I know a way to get the hole to match exactly but want to
know if anyone has a technique to do it since I can only drill from the
bottom and cannot use a drill press to get a matching hole. I matched
drilled the original holes all the way through. Also what are the
cautions about drilling the spring steel. [Shocked]
http://forums.matronics.com/viewtopic.php?p=368846#368846
