Dennis Thate
Posted: Sun Mar 04, 2012 11:10 am Post subject: Winter Storage question ? |
How often do you start your Rotax while in Winter Storage, .... or do you 'FOG'?
I found this little Sport Aviation gem down in Florida http://www.piairport.com/
Enjoy !
45.62 KB |
3099 Time(s) |
60.35 KB |
3099 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
Posted: Mon Mar 05, 2012 7:04 am Post subject: Winter Storage question ? |
Dennis T
I suppose that may be partly determined by which oil you use, synthetic has better lube properties, but runs off and leave bear metal exposed to the elements, I would fog,
mineral oil coats better and better prevents against corrosion,
I try and fly once or twice a month in the winter, and I use a durablend oil. and I try and get the best of both worlds. better lube and better corrosion prevention. I have over 700 hours on my 912, and still get 80 over 80 on a compression test.
boyd young
mkiii 912ul
Dennis Thate
Posted: Tue Mar 06, 2012 6:03 am Post subject: Re: Winter Storage question ? |
700 hours ...That's impressive !
I start mine every week, just to hear it run, when I'm here. It always starts on the first pull now, thanks to your advice.
