pulsar lll 3300 firewall forward onto a sp 100
barrynorman(at)comcast.ne
PostPosted: Tue Feb 21, 2012 1:14 pm    Post subject: pulsar lll 3300 firewall forward onto a sp 100 Reply with quote
I had to mount my battery on the inside of the firewall and move the instrument panel forward several inches on the Pulsar III to get the CG right with a 912. I also used a 3 inch
prop spacer to move it out for more forward CG.
To: pulsar-list(at)matronics.com
Sent: Monday, February 20, 2012 6:01:08 PM
Subject: Re: pulsar lll 3300 firewall forward onto a sp 100
Hello Bill,
I was out of touch for a full week so I could'nt respond to your question. I'll add a bit to what had already been posted here.
The SP100 shared the same FWL footprint as the pulsar III and you could mount a Rotax FWL FWD package onto a SP100. You'll need to mount the battery on the FWL to compensate for the lighter engine. Another good option was the Jabiru 3300.
Jabiru has a FWL FWD kit for it.
Hope this helped.
Solly Melyon
323.841.4822
--- On Thu, 2/16/12, Bill S <docyukon(at)ptcnet.net> wrote:
Subject: pulsar lll 3300 firewall forward onto a sp 100
Date: Thursday, February 16, 2012, 3:07 PM
--> Pulsar-List message posted by: "Bill S" <docyukon(at)ptcnet.net>
Is the firewall footprint of a sp100 the same as that of a Pulsar lll , Could a 3300 firewell fwd kit for a pulsar lll be grafted onto a sp100? any ideas? Bill S Pulsar l href="http://www.matronics.com/Navigator?Pulsar-List" target=_blank>ht="http://forums.matronics.com/" target=_blank>http://forums.matronics.c &nbsf="http://www.matronics.com/contribution" =======
sollymelyon(at)yahoo.com
PostPosted: Tue Feb 21, 2012 9:24 pm    Post subject: pulsar lll 3300 firewall forward onto a sp 100 Reply with quote
Guys,
The SP100 had the HS positioned 15" further back than the Pulsar III.  That should be properly counter balanced up front to arrive at the right cg.
Solly Melyon
323.841.4822
--- On Tue, 2/21/12, barrynorman(at)comcast.net <barrynorman(at)comcast.net> wrote:
From: barrynorman(at)comcast.net <barrynorman(at)comcast.net>
Date: Tuesday, February 21, 2012, 1:11 PM
#yiv2081817332 p {margin:0;} I had to mount my battery on the inside of the firewall and move the instrument panel forward several inches on the Pulsar III to get the CG right with a 912. I also used a 3 inch
Hello Bill,
Hope this helped.
Solly Melyon
323.841.4822
r-List
