Snazpappy
Posted: Fri Aug 09, 2019 2:30 pm Post subject: COMPRESSION CHECK |
I need to do a compression check on my engine to find out why I am burning/blowing out excessive oil.
I was told to do a differential compression check, I was reading the M14P maintenance manual and Task Card 248 "Check Of Cylinder Compression" instructs you to check compression with a pressure gauge.
My question is, Is one way better than the other?
I am referring to M14PF-XDK on a YAK 52TW
Snazpappy
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
Posted: Fri Aug 09, 2019 3:39 pm Post subject: COMPRESSION CHECK |
If the manual you reference does not provide specific parameters to check the compression with a pressure gauge, then my suggestion would be to use the industry accepted differential compression test.
Dennis
On Friday, August 9, 2019, 6:33:07 PM EDT, Snazpappy <snazman1(at)hotmail.com> wrote:
--> M14PEngines-List message posted by: "Snazpappy" <snazman1(at)hotmail.com (snazman1(at)hotmail.com)>
Snazpappy
http://forums.matronics.com/viewtopic.php?p=490780#490780
http://forums.matronics.com< - NEW MATRONICS LIST WIKI -
low" target="_blank">http://wiki.matronics.com
http://www.matr====
