wig wag reco lights
Dick Maddux
PostPosted: Mon Feb 06, 2012 6:00 am    Post subject: wig wag reco lights Reply with quote
I just installed my Aero Leds Micro Sun lights on my struts of my Fox 4. Now I can be seen from a long way away ! I have had a few close calls with Navy helo's here in the Pensacola,Fl area so this should improve my visibility a bit. They are SUPER bright !
I can only capture one flash at a time with my camera.
    Dick Maddux
    Fox 4
    Milton,Fl
 Filesize:  348.07 KB
 Viewed:  3085 Time(s)
 Filesize:  366.49 KB
kirkhull(at)kc.rr.com
PostPosted: Tue Feb 07, 2012 3:46 pm    Post subject: wig wag reco lights Reply with quote
Do you mind if I post the first pic on my website? I am trying to get more kitfox’s on is www.sportflight.net. If you don’t mind can you answer the following questions for the data base
N# ____________
Location / airport taken____________
www.sportflight.net
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Monday, February 06, 2012 7:56 AM
Subject: wig wag reco lights
    Dick Maddux
    Fox 4
    Milton,Fl
