Hopperdhh(at)aol.com Guest
Posted: Wed Feb 08, 2012 1:28 pm Post subject: King KR-86 Loop Cable |
I have a KR-86 ADF receiver and KA42 loop antenna, but no cable. I'd like to fabricate a cable.
Apparently the capacitance of the cable is critical. Can anyone tell me what this capacitance should be and how to measure it? Also, is the cable 2 separately shielded twisted pairs, or can the twisted pairs both be in the same shield, like telephone cable?
Thanks, Dan K9WEK
RV-7A 766DH flying since 2001
Posted: Wed Feb 08, 2012 4:44 pm Post subject: King KR-86 Loop Cable |
At 03:15 PM 2/8/2012, you wrote:
Apparently the capacitance of the cable is critical. Can anyone tell me what this capacitance should be and how to measure it? Also, is the cable 2 separately shielded twisted pairs, or can the twisted pairs both be in the same shield, like telephone cable? |
Not sure without schematics and a service
manual. There have been numerous service bulletins
over the years that called for confirmation
of a sense or loop cable assembly's capacitance.
For many radios of the era, coax capacitance
was an integral component of resonant or reactive
circuits within the receiver.
I recall writing accessory kits for ADF installations
wherein the installer fabricated a sense antenna
coax from some weird coax with a very tiny center
conductor in a relatively large hollow insulator
sleeve. Car radios used to use the same stuff . . .
very LOW capacitance/foot was key. Here's a tid-bit
I found on the 'net about low cap receiving coax:
The real reason car radios used ~90 ohm coax is 90-95 ohms works out to be the very highest impedance practical in a coaxial line having minimum possible shunt capacitance and reasonable outer and workable conductor size. This is entirely because of the short unloaded whip antenna on the car, and the AM broadcast bands low frequency that makes the antenna the tiniest fraction of a wave tall. The small car antenna is a voltage probe on AM broadcast. The short car antenna is an extremely high impedance source on the AM band. The AM receiver has a very high input impedance, ideally hundreds or thousands of ohms. Any shunt capacitance to ground in the connection between the receiver and antenna forms the lower leg of a voltage divider that reduces the RF voltage available at the AM radio input.
The car system is not operating in a normal transmission line mode.
This type of cable was also used for some old data lines, and it can work as a transmission line, but generally it is pretty lossy compared to other cables. After all, nearly all HF and VHF loss is caused by conductor resistance and this cable has a pretty thin center conductor.
As the article states, coax used in this application
is not behaving like a matched transmission line but
simply a shielded wire chosen to minimize the upset
for very high impedance receiver front ends.
RG62 is the only modern coax I can find with a low
capacitance (13.0 pf/ft). You could probably make
a new cable from this stuff if you knew what the total
allowable capacitance was . . . this sets cable
length.
These folks offer cables for KR-76 in various
lengths. Perhaps they fabricate them locally.
http://www.bennettavionics.com/kr86system.html
Bob . . . [quote][b]
Posted: Thu Feb 09, 2012 6:03 am Post subject: King KR-86 Loop Cable |
Thanks Bob,
I have the service manual, but there is no hint of what the capacitance or impedance is of the loop cables. It does show the cable as 2 separately shielded 2 conductor cables. The install manual gives 2 part numbers of cables (different lengths) and also says to not alter the length. One is 15 ft. and one is 24 ft.
I bought this radio and antenna at OSH for, I think, $25. I repaired the radio -- found a leaky capacitor in the synthesizer loop filter which caused a loud 1 KHz noise that covered up all signals.
This is just a hobby project, so I don't want to spend lots of money on it. I've already spent twice as much on manuals as the radio cost!
I am a EE, and have been a ham for over 50 years, built a lot of equipment, etc. There should be a way to solve this problem, but so far I haven't been able to! I'll try some things -- like measure the antenna inductance to get an idea of the impedance we're dealing with. I can also make some measurement on the goniometer, and front end coils that it feeds. That gets a little complicated!
Thanks for the help. If anything else comes to mind please let me know.
Dan
In a message dated 2/8/2012 7:47:36 P.M. Eastern Standard Time, nuckolls.bob(at)aeroelectric.com writes:
length.
Bob . . . |
Posted: Thu Feb 09, 2012 6:57 am Post subject: King KR-86 Loop Cable |
At 08:02 AM 2/9/2012, you wrote:
Quote: |
Thanks Bob,
I have the service manual, but there is no hint of what the capacitance or impedance is of the loop cables. It does show the cable as 2 separately shielded 2 conductor cables. The install manual gives 2 part numbers of cables (different lengths) and also says to not alter the length. One is 15 ft. and one is 24 ft. |
Could you scan the radio's front end schematic
and share it?
Quote: |
Thanks Bob,
Yeah. I seem to recall a tid bit from the dark recesses
of history that the longer cable was the 'golden' device
and the shorter one had padding capacitors in the connector
to make up the difference between the two.
I don't think there were any off the shelf, low capacitance
cables made as twisted pairs. Those would be comparatively
huge bundles. When they went to an internal goniometer,
the loop became less critical . . . impedance matching
could be accomplished in the gonio-transformer.
Do you intend to fly this radio? What's the expected
distance from radio to loop? If it's relatively
short, say on the order of 6-10 feet, I think I'd
try plain vanilla shielded pairs and see what happens.
I don't know if I ever knew . . . is this radio among
the ranks of those where the long-wire sense antenna was
eliminated?
Given the wide frequency coverage (250-1700 KHz)
1:7 ratio, it seem unlikely that antenna features
and feedlines will be in any way resonant. It seems
more likely that special attention be paid to ratiometric
values of impedance and phase. So I'm guessing that
the feedlines for this radio need only be identical
as opposed to trimmed for resonance.
Posted: Thu Feb 09, 2012 8:15 am Post subject: King KR-86 Loop Cable |
Hi Bob,
Mainly I just want to learn more about ADF. I also have a 1946 Stinson
(besides the RV-7A) that I may install it in once its working just to see
what ADF navigation is like, but that is some time away.
Yes, I'll try some plain vanilla cable to start with. I think that 6 to
10 ft. would work in the Stinson. Two ft. would work on the bench here.
If one knew the value of the padding capacitor and the length of cable it
replaced, that would answer the question, wouldn't it?
There is a bench setup in the service manual that mentions a cable (pn
200-0440-00) with capacitance of 144 pF. (I found this after sending the
email below.) It also shows a sense cable (pn 200-0447-00) with the same
capacitance. The loop cable part number is not the same as in the installation
manual, though!!
There is mention of a King Service Memo -- SM75 -- in The Technicians
Notebook by Jerry Gordon.
www.aerostandard.com/images/TecnNote.pdf
He says, "Its a long drawn out procedure to determine the proper ADF sense
antenna configuration. What it boils down to is you need a capacitance
meter in your shop." I know we're talking about loop antennas here, but I'd
be interested to see SM75 if you have access to it.
I can scan the test setup page and the receiver front end. I don't think
attachments will work on this list. How do I share the scans. I can send
them as .pdf files.
Dan
In a message dated 2/9/2012 9:57:56 A.M. Eastern Standard Time,
Thanks Bob,
and one is 24 ft.
eliminated?
Posted: Thu Feb 09, 2012 10:14 am Post subject: King KR-86 Loop Cable |
I forgot to answer this question.
Bob asked:
eliminated?
Yes, sort of, but not in my case:
The loop antenna I have -- KA42 -- requires a separate "50 pF" sense antenna. I see in the install manual that the radio is designed for 194 pF sense antenna system -- 144 pF cable plus 50 pF antenna. It also refers to Field Service Memo #75 which I would like to find.
The loop antenna KA42B has a built in sense antenna. It requires a matching assembly (pn 200-02104-0000). The schematic for this assembly is shown in the install manual. It feeds 8V to the antenna unit and uses 50 ohm coax -- length not critical. Apparently there is an amplifier in the antenna unit.
Dan
