moe-rosspistons(at)hotmai Guest
Posted: Fri Jan 27, 2012 3:39 pm Post subject: Hyd. Motor for Pres. |
Hi folks,
I need a serviceable Vickers Hydraulic Motor for the primary pressurization supercharger on my 680F(p). The part number on the motor tag is MF03380078. If you do not have a complete motor, I really only need the roller bearing inside the pump. My pump still puts out good pressure, it's just that it is so noisy that even drivers of early Lears complain about the noise on the tarmac.
Moe Mills
N680RR
Cell # (310) 350-4594
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
swperk
Posted: Fri Jan 27, 2012 4:05 pm Post subject: Hyd. Motor for Pres. |
Hi Moe,
Is it possible that the roller bearing is an industry standard part? And if the bearing is chattering, how is the shaft holding up?
Stan
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe Mills
Sent: Friday, January 27, 2012 3:37 PM
To: Com
Subject: Hyd. Motor for Pres.
Hi folks,
Moe Mills
N680RR
| Quote: | | < - The Commander-List Email Forum -http://www.matronics.com/Navigator?Commander-List | 01234567
gmosh(at)charter.net Guest
Posted: Sat Jan 28, 2012 9:48 am Post subject: Hyd. Motor for Pres. |
Moe,
Unless absolutely necessary, no design engineer would utilize specialized bearings in an assembly if a suitable one was available off the shelf. The cost of producing a special bearing produced in small numbers would be prohibitive. The bearing will likely sport a chemically etched part # on the race which you can use to find the replacement. With a little research, you should be able to find the bearing you need. {Never under any circumstances tell the bearing supplier its for an airplane....."It's for my garden tractor"}
I have successfully sourced seals, bearings etc. for my Commander from manufactures catalogs. I needed a seal for the gear box which I purchased from an engine re builder. The Chicago Rawhide package the seal came in was unopened (from the factory); was obviously not inspected (I wasn't surprised!) by Lycoming and the package simply stamped with the Lycoming part number and of course - marked up astronomically.
Hope this helps.
Gary
N206DX
On Fri, Jan 27, 2012 at 7:02 PM, Stan wrote:
Hi Moe,
Stan
To: Com
Hi folks,
Moe Mills
N680RR
http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution
ww.matronics.com/Navigator?Commander-List" TARGET="_blank">http://wONT>
nbsp; - MATRONICS WEB FORUMS -
< --> [/b][u]http://forums.matronics.com
aquadiver99(at)yahoo.com Guest
Posted: Sat Jan 28, 2012 10:19 am Post subject: Hyd. Motor for Pres. |
Amen Gary! I have great luck with "Motion Industries" for both brgs and seals.
Donnie Rose
205/492-8444
From: "gmosh(at)charter.net" <gmosh(at)charter.net>
Sent: Saturday, January 28, 2012 11:46 AM
Subject: RE: Hyd. Motor for Pres.
Moe,
Hope this helps.
Gary
N206DX
Hi Moe,
Stan
To: Com
Hi folks,
Moe Mills
N680RR
< --> [u]http://forums.matronics.com
" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Commander-List
et=_blank>http://forums.matronics.com
| [/u]
tylorhall(at)mac.com Guest
Posted: Sat Jan 28, 2012 2:55 pm Post subject: Hyd. Motor for Pres. |
Moe,There is a Motion Industries in Farmington, NM
I buy lots of stuff from them from the the ABQ store.
Tylor Hall
On Jan 28, 2012, at 10:46 AM, gmosh(at)charter.net (gmosh(at)charter.net) wrote:
| Quote: | Moe,
Hope this helps.
Gary
N206DX
Hi Moe,
Stan
From: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com) [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe Mills
To: Com
Hi folks,
Moe Mills
N680RR
< --> [u]http://forums.matronics.com[/u]
[/url]
[url=http://forums.matronics.com/][u]http://www.matronics.com/contribution[/u]
Posted: Sun Jan 29, 2012 9:28 am Post subject: Hyd. Motor for Pres. |
Thanks guys, I was "Trolling".
Tyler, Motion Industries is good, however, for machinery parts and so fourth I seem to be better off at Animus Bearing.
Moe
N680RR
Subject: Re: Hyd. Motor for Pres.
Date: Sat, 28 Jan 2012 15:52:56 -0700
Moe, There is a Motion Industries in Farmington, NM
Tylor Hall
[quote] Moe,
Hope this helps.
Gary
N206DX
Hi Moe,
Stan
To: Com
Hi folks,
Moe Mills
N680RR
[/url]
[/url] | Quote: |
face="courier new,courier">[url=http://www.matronics.com/Navigator?Commander-List]http://www.matronics.com/Navigator?Commander-List
| [b]
Posted: Sun Jan 29, 2012 9:31 am Post subject: Hyd. Motor for Pres. |
Date: Fri, 27 Jan 2012 16:02:23 -0800
.ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman","serif";} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman","serif";} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:"Courier New";} .ExternalClass span.ecxHTMLPreformattedChar {font-family:"Consolas","serif";} .ExternalClass span.ecxEmailStyle20 {font-family:"Calibri","sans-serif";color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page WordSection1 {size:8.5in 11.0in;} .ExternalClass div.ecxWordSection1 {page:WordSection1;}
Hi Moe,
Stan
To: Com
Hi folks,
Moe Mills
N680RR
89 | Quote: | | < - The Commander-List Email Forum - | 0 | Quote: | | < - The Commander-List Email Forum - | 1 | Quote: | | < - The Commander-List Email Forum - | 2 | Quote: | | < - The Commander-List Email Forum - | 3
swperk
Posted: Sun Jan 29, 2012 9:45 am Post subject: Hyd. Motor for Pres. |
Hi Moe,
I just did, and he sends his regards right back to you!
Stan | Quote: | | Hi Stan, Thanks for the input. I was "Trolling". Hope all is well in your world, tell Bob I said Hi. Moe N680RR Hi Stan, | 0123456789012345
Posted: Tue Jan 31, 2012 8:53 pm Post subject: Hyd. Motor for Pres. |
Commander Folks,
Rumors persist that 2012 will be the last race at Reno. Anyone up to having the fly in there? If we meet there, perhaps, we can borrow the Buick from the local FBO.
Moe
N680RR
680F(p)
Date: Sun, 29 Jan 2012 10:25:47 -0700
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Tahoma;} Thanks guys, I was "Trolling".
Moe
N680RR
Tylor Hall
[quote] Moe,
Hope this helps.
Gary
N206DX
Hi Moe,
Stan
To: Com
Hi folks,
Moe Mills
N680RR
[/url]
[/url] | Quote: |
st" target=_blank>http://www.matronics.com/Navigator?Commander-List
aero560e(at)GMAIL.COM Guest
Posted: Tue Jan 31, 2012 9:52 pm Post subject: Hyd. Motor for Pres. |
Sounds like a great idea Moe!
I vote for Reno
On 01/02/2012, at 2:20 PM, Moe Mills <moe-rosspistons(at)hotmail.com (moe-rosspistons(at)hotmail.com)> wrote:
[quote] Commander Folks,
Moe
N680RR
680F(p)
From: moe-rosspistons(at)hotmail.com (moe-rosspistons(at)hotmail.com)
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Moe
N680RR
Tylor Hall
| Quote: | Moe,
Hope this helps.
Gary
N206DX
Hi Moe,
Stan
To: Com
Hi folks,
Moe Mills
N680RR
[/url]
[/url]
| Quote: | http://www.matronics.com/Navigator?Commander-List
cs.com
