Looking for fuselage kit inventory
stuewe
PostPosted: Mon Feb 06, 2012 8:47 am    Post subject: Looking for fuselage kit inventory Reply with quote
Good morning,
I have been looking for an inventory list of the fuselage kit. I am just about to order this kit and thanks to this list, I'm pretty sure there are parts in it that I will want to delete and order elsewhere. I did a quick search and was unable to locate it. If anyone can post a reply with it or point me to it I'd appreciate it.
Stuewe
RV-10 (kit) 40933
Kelly McMullen
PostPosted: Mon Feb 06, 2012 9:09 am    Post subject: Looking for fuselage kit inventory Reply with quote
Caution....Over time Van's has changed what is in the fuselage kit vs
the finish kit, etc. So you want a list that is no more than a year or
so old.
I think you can call Van's and have them email or fax it to you. That
is best way to get current list.
On Mon, Feb 6, 2012 at 9:47 AM, stuewe <stuewe(at)gmail.com> wrote:
Good morning,
Stuewe
RV-10 (kit) 40933
http://forums.matronics.com/viewtopic.php?p=365732#365732
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
william(at)gbta.net
PostPosted: Mon Feb 06, 2012 9:46 am    Post subject: Looking for fuselage kit inventory Reply with quote
Stuewe, when you find it could you possibly forward a copy of it to me--if
it's not too much hassle. I'm a couple months from ordering. I'd also be
interested in knowing what you add/delete from the kit and if it's not too
personal, why you did add or delete. I'll keep an eye on these posts and
try to follow along and ask questions along the way.
By the way, I think Vans just implemented their 2012 price increase on 2/1.
Too bad you couldn't have ordered a week ago!!! (However, I have no idea
how much the increase was--probably fairly minimal anyway.)
Anyhow, good luck
Bill
Sent: Monday, February 06, 2012 11:04 AM
Subject: Re: Looking for fuselage kit inventory
so old.
> Good morning,
> Thanks
> Stuewe
> RV-10 (kit) 40933
wgreenley
PostPosted: Mon Feb 06, 2012 10:01 am    Post subject: Looking for fuselage kit inventory Reply with quote
For the fuselage kit it was about 4.6%, higher than normal. I wish I
had order but didn't want to store for four months.
Bill Greenley
On Mon, Feb 6, 2012 at 12:41 PM, Billy & Tami Britton <william(at)gbta.net> wrote:
Anyhow, good luck
Bill
> so old.
>> Good morning,
>> Thanks
>> Stuewe
>> RV-10 (kit) 40933
mregoan(at)hispeed.ch
PostPosted: Mon Feb 06, 2012 1:24 pm    Post subject: Looking for fuselage kit inventory Reply with quote
Hi Stuewe,
2 documents are attached. First is the Van's text file contents for the QB fuselage and wings.
Second is the pdf of my final packing list from early 2011. If you look on the last 2 pages of this document you will see things marked as "-1" in the "Qty to Pick" column - these are the items which I deleted after reading all the advice on the forum. The last page also shows stuff I ordered additionally from Van's along with the kit (Andair fuel valve, HID lights, etc).
In summary:
Change nose wheel and axle for Matco parts
I skipped tyres and tubes at this point and will order them with the windows and wingtip lenses from Desser
Bonaco brake lines replace the plastic lines and associated hardware.
Bonaco fuel and brake lines could replace the aluminum tubing except for the tank breathers (I did not delete the alloy tubing).
Andair fuel valve and pump.
Gear leg fairings from S.Africa
Hope this helps!
Gordon Anderson
41015
RV10_Q_KIT_CONTENTS_from_VANS.txt
 Filename:  RV10_Q_KIT_CONTENTS_from_VANS.txt
 Filesize:  34.04 KB
 Downloaded:  631 Time(s)
QB_kit_packing_list_20110308.pdf
 Filename:  QB_kit_packing_list_20110308.pdf
 Filesize:  583.5 KB
 Downloaded:  408 Time(s)
larkrv10(at)yahoo.ca
PostPosted: Mon Feb 06, 2012 7:05 pm    Post subject: Looking for fuselage kit inventory Reply with quote
Stuewe, I ordered the fuse kit in Sept 2011 and Vans faxed me the list with no questions asked. Yahoo mail just did something weird so you may get 2 responses from me.
Rick
#40956
Southampton, Ont
--- On Mon, 2/6/12, stuewe <stuewe(at)gmail.com> wrote:
Subject: Looking for fuselage kit inventory
Received: Monday, February 6, 2012, 4:47 PM
--> RV10-List message posted by: "stuewe" <stuewe(at)gmail.com (stuewe(at)gmail.com)>
Good morning,
Stuewe
RV-10 (kit) 40933
http://forums.matronics.com/viewtopic.php?p=365732#href="http://www.matronics.com/Navigator?RV10-List" target=_blank>http:http://forums.matronics.com/" target=_blank>http://forums.matronics.com
