Any thoughts on FLAPS?
Goto page 1, 2  Next
rsrandazzo(at)precisionma
PostPosted: Sun May 28, 2006 10:53 pm    Post subject: Any thoughts on FLAPS? Reply with quote
Commanders-
I'm still in the process of compiling me general fund of knowledge- and
thought you guys might be able to help with this mystery....
The Pilots Operating Handbook for the Commander 685 references conducting
all takeoffs with the flaps UP.
When I was checked out in N414C at purchase, the check pilot said that he
conducts all of his takeoffs at flaps 10.
I've used his advice- although for giggles I conducted one takeoff without
them just to feel the difference.
I found that performance (we are at 5200' MSL) was better with the flaps at
10, so this would seem to be my preference.
I have not scientifically conducted any takeoff distance/climb performance
measurements yet, obviously.
Anyone have any hard-fast logic on this?
Robert Randazzo
nico(at)cybersuperstore.c
PostPosted: Sun May 28, 2006 11:39 pm    Post subject: Any thoughts on FLAPS? Reply with quote
I don't even take off a Cessna 150 without flaps set to at least 10.
Although the Commanders don't have Fowler flaps, it still increases lift
more than it increases drag at 10 deg. It just makes sense to increase lift
on take-off. When flap settings will cause the plane to lift off before VMC,
then I will take off without flaps, but Commanders will run off the end of
the world if the pilot doesn't positively rotate. Moreover, if an engine
fails immediately after take-off (who's paying attention to balanced
fields?), I kinda like the spread between stall speed and airspeed with 10
deg flaps.
It's my 2c worth.
Nico
aquadiver99(at)yahoo.com
PostPosted: Mon May 29, 2006 8:18 am    Post subject: Any thoughts on FLAPS? Reply with quote
Hey Robert, I own a 500B but the differences are VERY
little. My POH says the same. What I have found to be
the most beneficial is flaps up or 10, no great diff,
but as soon as you start rolling, maintain back
pressure on the yoke so at 85 mph or so you are
airborne.
This technique reduces your ground roll and wear on
the nose wheel. Otherwise, you will remain on the
ground indefinitely until you finally pull back and
shoot up in the air.
--- "Robert S. Randazzo"
<rsrandazzo(at)precisionmanuals.com> wrote:
Randazzo" <rsrandazzo(at)precisionmanuals.com>
Commanders-
mystery....
Robert Randazzo
browse
Subscriptions page,
FAQ,
Admin.
Donnie Rose
205/492-8444
bowing74(at)earthlink.net
PostPosted: Mon May 29, 2006 8:44 am    Post subject: Any thoughts on FLAPS? Reply with quote
I like "shooting up in the air".
bilbo
BillLeff1(at)aol.com
PostPosted: Mon May 29, 2006 10:45 am    Post subject: Any thoughts on FLAPS? Reply with quote
That is true. The aircraft performs better as far as getting off the ground
with 1/4 flaps but it degrades single engine performance. Just be careful and
get those flaps up as soon as you get the gear up.
Bill Leff
CloudCraft(at)aol.com
PostPosted: Mon May 29, 2006 9:52 pm    Post subject: Any thoughts on FLAPS? Reply with quote
In a message dated 28-May-06 23:54:44 Pacific Daylight Time,
rsrandazzo(at)precisionmanuals.com writes:
Robert,
In the words of Donald Rumsfeld, "There are things we know, there are things
we don't know and there are things we don't know that we don't know."
I know a few things about Commanders, I know there are a few things I don't
know about Commanders, and the rest is obvious.
I have never been able to figure out why the 685/690 airframes are zero flap
take-off models.
I found 10 degrees of flaps to be really effective on the 685; I operated
mostly out of Lee's Summit in Missouri (KXLT) at 1000' on a 4010' runway. I
could see the end of it; it was too short.
Things I know: 10 degrees of Commander flaps are lift. More than that is
drag. More than half flaps is a lot of drag.
Ted Smith airplanes (Commander, Aerostar, Jet Commander / Westwind) sit at a
negative angle of attack on the ground. For the science fans in the crowd,
this was something I intuited and was confirmed by Ron Smith, Ted Smith's son.
The negative angle of attack stance serves you on a short field landing but
is something you have to overcome on take-off.
This explains the "leaping into the air" as Donnie has discovered. If one
accelerates without back pressure on the yoke a Commander will pearl dive and
then with a hefty pull at your preferred Vr, you'll overcome the negative AOA
and leap.
Try this: have a companion stand outside at the tail and yell to you when the
elevator is streamlined. Make note of where the yoke is. Now hold the
yoke there at the start of your next take-off roll.
As you accelerate, the amount of back pressure to hold a streamlined elevator
will become less and you'll smoothly fly off. (The bob weight for pitch feel
will make you exercise a bit at each take-off; this counts towards your
weekly gym time.)
If anyone out there knows -- or has anyone they can reach back to, who was
involved with the 690 airframe design and certification who can enlighten me as
to why this is a zero flap take off (per the AFM) please do let me know. One
theory I've heard is that the straight wing stub gave more lift than the
continuous dihedral wings on other models and therefore flaps were not necessary.
My experience in the 685 does not bear this out. On the Turbo Commanders,
there's just so bloody much power and airflow over the inboard wing section
that the take-off is a brief blur anyway and flaps would just be ... silly.
David Maytag, do you have any insight into this mystery? You and your family
have been around this model longer than a week.
Wing Commander Gordon
Life is not simple anywhere. Probably less so elsewhere.
BobsV35B(at)aol.com
PostPosted: Tue May 30, 2006 1:15 am    Post subject: Any thoughts on FLAPS? Reply with quote
Good Morning Wing Commander Gordon,
I absolutely DO NOT have any personal knowledge as to why the later Aero
Commanders do not recommend flaps for takeoff, but I DO have a little knowledge
as to why the later Bonanzas do not recommend flaps for takeoff.
The FAA told Beech that if they were going to show any data for flapped
takeoffs, they had to run tests under the observation of FAA inspectors to verify
the data in accordance with FAA specifications. The cost was high, but even
beyond that, the Beech Lawyers told management to back off and leave it alone
for liability reasons.
There is no prohibition against using flaps, but there is no official
encouragement either.
I would not be at all surprised if Aero Commander encountered similar FAA
and lawyer problems.
One more comment. Ted Smith designed the airplane during the time when the
industry was beginning to take advantage of the minimum, or negative, angle of
attack on takeoff mode to aid acceleration on the ground.
If any of you are old enough to remember the Convair 240 as against the
Convair 340, you may remember that the 340 sat on the ground with the nose a bit
lower than did the 240. The idea was to reduce the drag during the
acceleration mode. It allowed for a slightly shorter accelerate stop number.
Just to add more data about which I know very little, back in the olden days
when I was flying Commanders a bit, I generally preferred the flapped
takeoff, but I never did see any numbers developed that would have allowed me to
estimate the effect it had on accelerate stop distance.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 5/30/2006 12:52:59 A.M. Central Standard Time,
CloudCraft(at)aol.com writes:
as
One
necessary.
PostPosted: Tue May 30, 2006 11:05 am    Post subject: Any thoughts on FLAPS? Reply with quote
Bob-
Following this observation:
days when I was flying Commanders a bit, I generally preferred the flapped
me to estimate the effect it had on accelerate stop distance.
I noticed that the airplane leaves the runway more affirmatively at Flaps10
than Flaps0. At Flaps0, the airplane seemed to wallow for a moment when
leaving ground effect. I didn't get the same impression at Flaps10....
Once N414C is flying again- I'll take some notes and see how performance
differs. Even though we don't have any specific information it might make
for some good knowledge all the same.
Robert Randazzo
PostPosted: Tue May 30, 2006 11:10 am    Post subject: Any thoughts on FLAPS? Reply with quote
WCG-
Interesting notes on the neutral position. Filed away for future use. I'll
post my feedback at that time.
Robert Randazzo
PostPosted: Tue May 30, 2006 12:00 pm    Post subject: Any thoughts on FLAPS? Reply with quote
With Flaps 0, one would have a steeper deck angle; the rotation would then
be through more degrees. A steeper deck angle is also a scary part for me so
close to the ground at minimums. (minima)
STOLHorse(at)aol.com
PostPosted: Tue May 30, 2006 4:05 pm    Post subject: Any thoughts on FLAPS? Reply with quote
This is one of those questions I've wondered about for a long time, too.
Here's my thoughts on the subject:
I think Old Bob is on the right track and they maybe just didn't test it
because, as Keith said, the 690's have so much power that it just didn't make
enough difference to justify the time and expense of the testing and approval of
the data. As airplanes evolve, the manufacturers are all guilty of "evolving"
the data and procedures along with it from previous models. Usually, this is
no big deal but you can find examples of it everywhere, even on certain TC
Data sheets. Perhaps this is the case with the 685 too. Since it came after the
690, maybe the culture was to change as little as possible and the flaps-up
take off just came along. I don't know. Giving the engineers the benefit of
the doubt, though, I just figured it had something to do with meeting single
engine climb requirements so I take off with the flaps up in the 685.
The technique I've been using to coax the 685 off the ground has been working
well for me and I fly it at or very near gross weight and I go to high
altitude airports. I will not take it to Aspen or Telluride, however. The places I
go do have pretty good options should the airplane decide it just can't do it
on one engine. I always seem to come up with about 120 to 200 fpm climb on
one engine when I check the performance numbers. I just don't have a whole lot
of confidence in those numbers in the real world with a scared-$%^*less me at
the controls vs. the highly skilled and expecting it test pilot.
I take off with full power and I take my time getting the engines to full
power so I don't thermally shock them or cause the turbo to surge. If it's busy,
I'll even ask for a momentary delay on takeoff so the controllers will know
I'm not going to blast out of there like a 690. At brake release, I have my 8
year old son close the cowl flaps for me while I go in the back to get my
lunch. (In my opinion, the cowl flaps affect takeoff performance much more than
the difference in flap settings.) After I get back to the front seat with my
sandwich, I see that we are approaching Vr. I like to leave the 685 on the
ground about 8 to 10 knots above the book Vr of 92 kias. I rotate at about 95
and lift off about 100 or even a bit above that. It's about the same as the
690's. My theory here is that speed is my best friend right now because it seems
to take forever to get from liftoff to 111kias Vyse. I don't want to pull it
off way down around 90 (the short field technique calls for 83 indicated -
yikes!) and double the speed that I need to gain to get to the best SE climb. I
don't go to short runways so that is not a factor in this technique. Also,
liftoff at 100 knots is very gentle and positive. That's one of my favorite
things about Commanders: If you set the trim right, you can make the most
effortless and smoothest transition from ground to air that I have experienced in
any plane - something King Airs can only dream about. While the airplane
accelerates, I watch the engine temps and adjust the cowlflaps accordingly.
Usually in the winter they just stay closed but in summer, especially out of Bermuda
Dunes, I need to open them halfway or so. You can see the temps rising on
takeoff but as soon as you open the cowl flaps just a little they will stop
rising almost immediately and I've never seen them go above 400 degrees even in
the heat. There's just a ton of cooling drag on this plane and with the cowl
flaps open you get 4 nifty little spoilers working against you too.
Anyway, if you're still reading, that's my two cents worth. Bottom line is
that I pick my airports very careful with this plane but I have found that the
685 has exceeded my expectations by a large margin. I think most of the
badmouthing of the airplane is unfounded and a result of comparing it to the 690's.
Let's compare it to a 421 or P-Navajo. Oh yeah, there's no comparison.
David Maytag
PostPosted: Tue May 30, 2006 4:26 pm    Post subject: Any thoughts on FLAPS? Reply with quote
I had heard a friend talk about the effect of the cowl flaps on the
Commander and never thought much about it until I was trying to figure out
why my 500A wouldn't "Go". It wouldn't climb, hardly at all, and the speed
at level off was just not there. Invariably I would look back and see the
cowl flaps open.
I found 2 things.
1 if I could see them the performance was going to be dramatically effected.
2 on the 500A it doesn't matter whether they are open of closed. The temps
are always cold. So I will leave them closed.
If I ever get it flying again.
bilbo
PostPosted: Tue May 30, 2006 4:28 pm    Post subject: Any thoughts on FLAPS? Reply with quote
David-
Thanks for the info! Apsen/Telluride.... I've flown Part 121 airplanes
loaded with passengers in/out of those places and didn't feel comfortable
with my options. I'd never conceive of taking the 685 there.
The beauty of tossing a set of Chelton's into this airplane is that the
Flight Path Vector becomes a very handy tool when navigating rising terrain
with a climb performance problem.
You mind sharing a bit of your experience on runway length and your
"selection process?" (You mentioned that you pick your airports
carefully... Thought I might gain from your experience...)
I operate out of a field with 7000 and 9500' of runway- which provides me
with plenty of opportunities. Generally speaking I'm headed to places with
11000+ in runway length- but I imagine that as I get more comfortable with
the bird I'll be using it into some smaller spaces as well.
I like to take my time getting used to new airplanes....
You get your props worked out, David? Both props on N414C overhauled with
no problems- but I had my fingers crossed after hearing about yours...
Robert Randazzo
john(at)vormbaum.com
PostPosted: Tue May 30, 2006 5:56 pm    Post subject: Any thoughts on FLAPS? Reply with quote
David,
Bermuda Dunes!!!!!
On a balmy 105-degree Palm Desert day, that runway seems awful short to me.
You're a brave man to be flying a 685 out of there.
/John
PostPosted: Tue May 30, 2006 6:43 pm    Post subject: Any thoughts on FLAPS? Reply with quote
Yep, the Chelton system is awesome. I think it's the best system you can buy
right now.
I don't have any kind of scientific way I pick airports I just meant that I
look at the surroundings and temperatures more than just runway length.
Aspen's runway is long enough but the valley gets pretty narrow and highway 82 is
dangerous enough without 9000 pound puddle jumpers skimming the rooftops of
SUV's at 150 miles an hour. I like to see a lot of open space and flat or
lowering terrain. I've noticed that the airplane will climb pretty well once it
reaches 120 or so which is why I like to get it to that speed or more as fast as I
can. At full power and gross weight, I see about 1200- 1300 fpm at gross
weight coming off of a 5000' elevation airport. I just don't like to leave them
at full power any longer than necessary (even though Continental says you can
all day long) and at max recommended climb power I see around 700 fpm so
mountain valleys are something I avoid. I'm also much more cautious about weather
in this plane. I don't do low ceilings (as in less than a few thousand feet)
or any moist winter cold fronts where the possibility of ice is obvious.
I did finally get a pair of sharp looking overhauled propellers just last
Friday. It was a challenge but with my spare prop and some careful searching by
the good folks at Nevada Propeller/Executive Propeller, we finally came up
with 6 real good blades and one hub. I was really worried though at first
because the initial reaction from all the prop shops was one of complete futility.
You know like "Oh, I haven't seen one of those props in 30 years" or "What
model of prop did you say that was?" or "What model of Commander did you say
those go on?"
PostPosted: Tue May 30, 2006 8:28 pm    Post subject: Any thoughts on FLAPS? Reply with quote
John,
You've exposed my hypocrisy already!
Actually, Bermuda Dunes is the shortest runway I've gone to but the airplane
does just fine. I don't fly out of there heavy in the middle of the
afternoon, though. I always plan the heavy departures for early morning but I have
left there lightly loaded in 105 degrees. It's still not as scary as flying
heavy 747-100's out of Ramstein on a hot afternoon!
I'm sure most of you can appreciate the load hauling capability of
Commanders, But I have to tell you what my "normal load" is when I go to Bermuda Dunes:
Two dogs,
Two cats,
Two women,
Two kids,
and Me.
Plus enough fuel to go 650 miles with reserves. Oh yeah, and I'm not
talking about two lap dogs -- one is a Labrador and the other is a Great Dane.
Luckily, they are good buddies.
I need help.
David Maytag
PostPosted: Tue May 30, 2006 8:33 pm    Post subject: Any thoughts on FLAPS? Reply with quote
In a message dated 30-May-06 21:28:51 Pacific Daylight Time,
STOLHorse(at)aol.com writes:
Two dogs,
Two cats,
Two women,
Two kids,
and Me.
I need help.
Help? Sounds like you need a HAZMAT program!
By the way, thanks for bringing up the matter of cowl flaps. That's an
important piece of the take-off puzzle.
tfisher(at)commandergroup
PostPosted: Tue May 30, 2006 10:35 pm    Post subject: Any thoughts on FLAPS? Reply with quote
My German Short Haired Pointer (75 Lbs.) has the bench seat to himself.
I operate at gross weight all the time from 3500' sea level runways.
I lighten my nose wheel at 80 mph and rotate at 105 mph with 10 deg. flaps.
Tom F.
C-GISS 680 FLP (Mr.RPM)
barry.collman(at)air-brit
PostPosted: Wed May 31, 2006 2:31 am    Post subject: Any thoughts on FLAPS? Reply with quote
Hi All,
I've flown with an Iguana. Beat that!!!!!
Barry C.
rcdettmer(at)charter.net
PostPosted: Wed May 31, 2006 5:42 am    Post subject: Any thoughts on FLAPS? Reply with quote
I have been enjoying the discussion about flap settings on take-off, and
short vs long runways at high and hot airports. Just want to share my
experiences in my 680F. I have routinely been using 10 degrees of flaps for
takeoff, with rotation at 80 kts, initial climb at 100 kts, and cruise climb
(after about 800 feet asl) at 140 kts and 1000 fpm. Doesn't seem to change
whether light or at gross weight (8,000 lbs)...always the same 140 kts and
1,000 fpm. If the air temp isn't too hot, I will take off with cowl flaps
in trail (about half open)...desn't seem to affect climb performance, but
would probably make a difference on one engine. I remember coming out of
Carson City and Las Vegas at near gross weight (7 persons and lots of
baggage) in summer with air temps well above 90...airplane jumped off the
runway and performed as if it was wintertime. Of course, those runways have
plenty of length and flat land around if one engine quits.
Thanks for the good discussions
Randy Dettmer, AIA
680F / N6253X
DettmerArchitecture
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
Goto page 1, 2  Next
Page 1 of 2
