Posted: Tue Jan 31, 2012 1:56 pm Post subject: Dorne & Margolin DM C63-1 antenna |
| Quote: | I am wondering if I could just bend the one I have I have to meet
the clearance needed for a belly mount.
The pictures I see for this antenna appear to show
a painted antenna rod. Is this a solid metal rod
or is it some kind of conductor stuck inside a fiberglas
sheath?
jerrytex
Posted: Tue Jan 31, 2012 4:20 pm Post subject: Re: Dorne & Margolin DM C63-1 antenna |
I am not sure if its metal or not. I am not near the plane and was wondering if anyone knew. I was trying to get my gameplan down before I go back to the hangar an hour away. This also got me to thinking... I was looking at the DIY CB antenna and I was thinking this might be the best route for me if I could bend it. Will mounting it on the belly and bending it back cause problems?
Posted: Tue Jan 31, 2012 8:46 pm Post subject: Dorne & Margolin DM C63-1 antenna |
Bending the antenna has very little effect on performance.
The "business section" of a vertical antenna is in the
bottom 1/3rd or so, bending the upper 2/3rds has the effect
of electrically lengthening or lowering it's resonant frequency
but even that effect is minimal.
jerrytex
Posted: Wed Feb 01, 2012 7:13 am Post subject: Dorne & Margolin DM C63-1 antenna |
At 07:53 AM 2/1/2012, you wrote:
Thanks Bob for the info.
I checked Radio Shack and found this CB mount.
http://www.radioshack.com/product/index.jsp?productId=2102429
It looks like the one in your DIY article. If my thinking is correct,
I could use this mount and this antenna:
http://www.radioshack.com/product/index.jsp?productId=2102428
And cut it down to the 22" that you mention in the article, mount it
with a ground plane to the belly of the plane and bend the top 2/3's
back for clearance.
What do you think?
I think you have a useful command of the simple
ideas behind a solution of your antenna problem.
You're cleared for 'take-off'.
