down trust angle
teamgrumman(at)yahoo.com
PostPosted: Sun Jan 22, 2012 2:35 pm    Post subject: down trust angle Reply with quote
I've been doing some work on Papa John's 6-cylinder Cheetah. I noticed the cowling alignment and the change side-to-side. His down thrust is measured at about 1 to 1.1 degrees down.
 Filesize:  1.01 MB
 Viewed:  1279 Time(s)
 Filesize:  995.71 KB
flyv35b(at)minetfiber.com
PostPosted: Mon Jan 23, 2012 5:17 am    Post subject: down trust angle Reply with quote
Is that good or bad? The spacer between the fuselage and cowling is
tapered (wider at the top).
Cliff
PostPosted: Mon Jan 23, 2012 1:27 pm    Post subject: down trust angle Reply with quote
The engine needs to be down to reduce the need for trim when changing power.
Sent: Monday, January 23, 2012 5:13 AM
Subject: Re: down trust angle
--> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
Is that good or bad? The spacer between the fuselage and cowling is tapered (wider at the top). href="http://www.matronics.com/Navigator?TeamGrumman-List" target="_blp; &n==================
