ronko(at)att.net Guest
Posted: Tue Jan 10, 2012 1:17 pm Post subject: Aileron Hinge Pin |
Pulsar Fans,
I was about to replace a worn hinge on my right aileron on the Pulsar, because replacing the pin with a new one, there still was some undesirable play in the hinge.
Then a good friend of mine, who built and flies a Lancair 360 gave me a 3/32" stainless steel welding rod. The rod is 5 thousandths larger diameter than a new conventional piano hinge pin. It slide in with minimal effort, just like it was meant to be and the play in the hinge is virtually gone (for now; wear is an inescapable reality). It sure beats the work I was anticipating to replace the hinge itself. Eventually the hinge itself will need replacing.
Best regards,
Ronko
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
