Posted: Tue Jan 10, 2012 11:02 am Post subject: Grumman Airfoil |
I was looking at the airfoil on a Socata Trinidad and it looks a lot like the Grumman.
It's an RA 16.3C3 airfoil. I can't find any info on it either
Posted: Wed Jan 11, 2012 8:11 pm Post subject: Grumman airfoil |
The Socata Trinidad airfoil is an RA 1643 or RA 16.3c3
The Avions Transport Regional ATR-72 uses an RA 1843 airfoil. This is a NACA 43018 Mod.
It's my guess that the RA 16.3c3 is the Grumman airfoil. Now all we need are lift/drag curves.
n76lima(at)mindspring.com Guest
Posted: Thu Jan 12, 2012 10:29 am Post subject: Grumman airfoil |
| Quote: | The Socata Trinidad airfoil is an RA 1643 or RA 16.3c3
Based on your transposition of the digits in the ATR-72 airfoil
(which has been shown to have a dangerous proclivity to build ice
that destroys the lift...), one would surmise that the "RA1643"
airfoil is a "43016" (mod?) airfoil.
I haven't seen this overlayed on the Grumman bastardization of the
NACA laminar flow airfoil used on the Yankee, but would say that if
it is a close match, then the L/D curves would at least point us in
the right direction of understanding the Grumman modded airfoil.
Are you basing your suggestion of identicallity on actual plots
overlaid, or on the relative appearance of 2 smaller samples compared
side by side?
Damn little info found through Google on either the RA 1643 or the RA
16.3c3, other than some listings of which planes they have been used on.
--Bob Steward
dsleepy47
Posted: Thu Jan 12, 2012 12:38 pm Post subject: Grumman airfoil |
If someone can provide a .dat coordinate file I can provide the lift/drag curves.
Deems
Date: Wed, 11 Jan 2012 20:08:10 -0800
Subject: Grumman airfoil
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
http://forums.matronics.com
_________________ dsleepy47
N1491R |
Posted: Thu Jan 12, 2012 8:21 pm Post subject: Grumman airfoil |
I cannot find any L/D curves for any RA airfoils.
The RA 1843 is an older NACA airfoil. It wasn't that good then. We need to find a comparable '6' series airfoil.
Sent: Thursday, January 12, 2012 10:25 AM
Subject: Re: Grumman airfoil
--> TeamGrumman-List message posted by: Bob Steward <n76lima(at)mindspring.com (n76lima(at)mindspring.com)>
Based on your transposition of the digits in the ATR-72 airfoil (which has been shown to have a dangerous proclivity to build ice that destroys the lift...), one would surmise that the "RA1643" airfoil is a "43016" (mod?) airfoil.
I haven't seen this overlayed on the Grumman bastardization of the NACA laminar flow airfoil used on the Yankee, but would say that if it is a close match, then the L/D curves would at least point us in the right direction of understanding the Grumman modded airfoil.
Are you basing your suggestion of identicallity on actual plots overlaid, or on the relative appearance of 2 smaller samples compared side by side?
Damn little info found through Google on either the RA 1643 or the RA 16.3c3, other than some listings of which planes thatronics.com/Navigator?TeamGrumman-List" target="_blank">http://www.matronbsp; =
Posted: Thu Jan 12, 2012 8:22 pm Post subject: Grumman airfoil |
Sadly, I can't find that either.
Sent: Thursday, January 12, 2012 12:35 PM
Subject: RE: Grumman airfoil
Deems
Subject: TeamGrumman-List: Grumman airfoil
http://www.matronics.com/Navigator?TeamGrumman-L=====================
