A correction
barry.collman(at)air-brit
PostPosted: Tue Jan 10, 2012 6:17 am    Post subject: A correction Reply with quote
Hi Bert,
You might recall that there was some confusion as to whether 690A s/n 11315 became XA-OUJ or XA-UOJ when N561TC was cancelled in July 2010.
From memory, I had XA-UOJ originally, then corrected it to XA-OUJ when the attached photo was found.
It was compared to the shot of it in the former marks N561TC, which is also attached and it certainly seems to be the same aircraft.
When I sent comments to a few Air-Britain guys re the FAA changes from last week, one of them said a contact of his in Mexico maintained it was XA-UOJ after all.
Consequently, I sent a request to a friend in the FAA PD Room and they kindly send a .pdf file of the Mexican Telex confirming cancellation, and this clearly shows XA-UOJ and as usual, they show the radio call letters as “Extra Alfa Union Oscar Julieta”.
So, it now looks as though “XA-OUJ” was painted on this 690A in error for XA-UOJ.
Best Regards,
Barry
 Filesize:  424.04 KB
 Viewed:  1645 Time(s)
 Filesize:  47.56 KB
BertBerry1(at)aol.com
PostPosted: Tue Jan 10, 2012 8:06 am    Post subject: A correction Reply with quote
Thanks Barry,
Now in understand that it is N31BV back in the states. Its been painted about a dozen different times.
Bert
In a message dated 1/10/2012 8:19:37 A.M. Central Standard Time, barry.collman(at)air-britain.co.uk writes:
Hi Bert,
Best Regards,
Barry
