Outrigger Pivot Bearing
roddyeuropa(at)aol.com
PostPosted: Mon Jan 09, 2012 2:37 pm    Post subject: Outrigger Pivot Bearing Reply with quote
Hi
Does anyone know where I can get the stainless steel tube needed to do the standard outrigger bearing mod (LAA mod 10661 - on the club website) in the UK ?
Roddy Kesterton
#220 G-IKRK
graeme bird
PostPosted: Tue Jan 10, 2012 9:34 am    Post subject: Re: Outrigger Pivot Bearing Reply with quote
I'd like to know too. I brought what I thought was the right sizes to do this mod but one wouldnt fit in the other.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
rlborger(at)mac.com
PostPosted: Tue Jan 10, 2012 11:38 am    Post subject: Outrigger Pivot Bearing Reply with quote
Roddy & Greame,
I have no idea where you can find it in the UK, but it's available from McMaster-Carr here on this side of the pond.
McMaster has this and only this:
MaterialType 440C Stainless SteelShapeStructural TubesStructural Tube TypePlain RoundStructural Tube TolerancePrecision-GroundOutside Dia.3/8" (.375")Outside Dia. Tolerance-.0002"Inside Dia.5/16" (.3125")Inside Dia. Tolerance+.0002"Length6"Length Tolerance±.01"RockwellC50-C55Specifications MetAmerican Society for Testing and Materials (ASTM)ASTM SpecificationASTM A276
[img]cid:E5BE8B38-BA4A-4346-AFD3-56A4A5B825F3[/img]
for a price of $99.74 + shipping. That's UKŁ64.50 + shipping. Whooeee, I don't remember that it cost that much several years ago when I did the mod, but that's what it is now.
You can go to McMaster.com and search on Stainless Steel Tubing.
On that page you can specify the OD and ID which will bring up the above.
A 6 inch length should be sufficient for at least 2 mods so it isn't quite as painful to the purse if you share.
You may order it directly from McMaster or if you wish, I'll be glad to order the tubing and forward it on to either of you. Once I know the end costs after shipping, you can post it to my PayPal account. Hopefully the import tariff on your end won't be a killer.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Jan 9, 2012, at 4:33 PM, roddyeuropa(at)aol.com (roddyeuropa(at)aol.com) wrote:
Hi
Roddy Kesterton
#220 G-IKRK
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
 Filesize:  34 Bytes
 Viewed:  9524 Time(s)
graeme bird
PostPosted: Tue Jan 10, 2012 11:46 am    Post subject: Re: Outrigger Pivot Bearing Reply with quote
I could check out Chronos in dunstable, beds, uk again with that spec, it should be right up thier street.
Graeme Bird
kit4 (Wagstaff) TBD
churchy
PostPosted: Wed Jan 11, 2012 12:07 am    Post subject: Outrigger Pivot Bearing Reply with quote
Graeme
If it should turn out that Chronos have the material but only in expensive
minimum quantities then I will be carrying out the Mod at some point and
would be happy to share costs.
Richard
XS Mono/912ULS.....becoming a slightly more organised pile of parts....
flyingphil2
PostPosted: Wed Jan 11, 2012 1:33 am    Post subject: Re: Outrigger Pivot Bearing Reply with quote
Roddy / Graeme,
I did get some tube for this mod but it was slightly wrong when it arrived although it was fine after being turned down on a lathe.
Er, I'm not sure what I did with the rest (I had to buy 1 metre) but I'll have a look. I may have donated it to my place of work so I'll have a fish around there.
Phil
flyingphil2
PostPosted: Fri Jan 13, 2012 6:07 am    Post subject: Re: Outrigger Pivot Bearing Reply with quote
Roddy / Graeme,
I believe that I've found the stainless tubing offcut that I used for this. Can you remind me of the ID and OD so that I can measure it and check. I do remember having to turn one diameter down on a lathe but I can't remember which one.
Phil
rlborger(at)mac.com
PostPosted: Fri Jan 13, 2012 6:28 am    Post subject: Outrigger Pivot Bearing Reply with quote
Phil,
From the Mod PDF:
Stainless Tube (0.375”outsidediameter,0.3125”insidediameter) The inside of the stainless tube is the critical dimension so that it provides a sliding fit for the AN5 bolt. A slightly larger outer diameter is acceptable which will require a larger hole in the OR1.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 13, 2012, at 8:07 AM, flyingphil2 wrote:
Roddy / Graeme,
Phil
tennant
PostPosted: Fri Jan 13, 2012 8:27 am    Post subject: Re: Outrigger Pivot Bearing Reply with quote
If you can use it I have bunches of Chrome Molly tube 10 x 1,0 = 0,393 OD x 0,315 ID.
Free of charge for these little bits.
Barry Tennant
Barry Tennant
D-EHBT
At EDLM - Germany
