andy717(at)comcast.net Guest
Posted: Wed Jan 04, 2012 2:27 pm Post subject: 14 volt bus / voltage regulator? |
Looking for a voltage regulator recommendation:
I need a small 14 volt bus bar in order to service ray allen servos and maybe a couple other 14 volt devices. I will be running a 28 volt system and would prefer to have a separate 14 volt bus. If anyone has any recommendations, or tips on how to go about servicing disparate voltage components, I’m much obliged --
Thank you,
Andy
Posted: Wed Jan 04, 2012 3:31 pm Post subject: 14 volt bus / voltage regulator? |
Ray Allen makes a 12V regulator just for 28V aircraft, P/N REG-1.
Otherwise we've installed something like this for 12V items:
http://www.wmjmarine.com/vtc60-24-12.html
These days you can't really get by without a few 12V outlets.
When we had the luxury, we've gone so far as to install a complete 12V battery and alternator, but that was on a turbine with lots of spare drive pads.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Wed, Jan 4, 2012 at 2:17 PM, Andy Hawes <andy717(at)comcast.net (andy717(at)comcast.net)> wrote:
[quote] Looking for a voltage regulator recommendation:
Thank you,
Andy
tp://forums.matronics.com
DVorsas(at)triumphgroup.c Guest
Posted: Thu Jan 05, 2012 8:56 am Post subject: 14 volt bus / voltage regulator? |
Andy,
I used a Collins PWC-150. It has two independent channels, either of which will handle all of the Ray Allen servos. I put an "on-off-on" toggle switch so that I had both a primary and a back up 14vdc output. Protect the circuit with a circuit breaker, and you are all set. You can also use a King KA-39, although if I remember correctly, it is only one channel. Either unit is available on E-bay for around $100 or less. Most avionics shops are littered with these units.
On a side note, I just powered up my panel, everything works, no smoke, no components changed color, and no thermal events!
Good Luck,
David Vorsas
Radial Rocket N385BV
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Andy Hawes
Sent: Wednesday, January 04, 2012 5:18 PM
Subject: 14 volt bus / voltage regulator?
Thank you,
Andy =======================[/b][/quote] p; - The AeroElectric-List Email Forum -[/b][/quote] avigator to browse[/b][/quote] ist Un/Subscription,[/b][/quote] Day Browse, Chat, FAQ,[/b][/quote] :p>[/b][/quote] p://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List[/b][/quote] =======================[/b][/quote] p; - MATRONICS WEB FORUMS -[/b][/quote] via the Web Forums![/b][/quote] p://forums.matronics.com">http://forums.matronics.com[/b][/quote] =======================[/b][/quote] p; - List Contribution Web Site -[/b][/quote] support![/b][/quote] p; -Matt Dralle, List Admin.[/b][/quote] p://www.matronics.com/contribution">http://www.matronics.com/contribution[/b][/quote] =======================[/b] [/quote]
This message has been processed via your triumphgroup.com e-mail address.
Posted: Thu Jan 05, 2012 2:08 pm Post subject: 14 volt bus / voltage regulator? |
ok, that sounds like the ticket — thank you. I found this part number after matching up the converter specs you gave me with DigiKey that should save you a few bucks if you need this again in the future:
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=102-2273-ND&x=20&y=15
digikey part number: 102-2273-ND this is a smaller device and 12.5 amperage output.
Just wondering if you guys use an inline fuse with this type of device? Or would you rather have a breaker available to the pilot just in case the device ever has an issue in flight?
Thanks for the recommendation --
Andy
On 1/4/12 5:23 PM, "Dave Saylor" <dave.saylor.aircrafters(at)gmail.com> wrote:
| Quote: | Ray Allen makes a 12V regulator just for 28V aircraft, P/N REG-1.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Wed, Jan 4, 2012 at 2:17 PM, Andy Hawes <andy717(at)comcast.net> wrote:
| Quote: | Looking for a voltage regulator recommendation:
Thank you,
Andy
ist" target="_blank"><mailto:andy717(at)comcast.net> (andy717(at)comcast.net)
tp://forums.matronics.com <mailto:andy717(at)comcast.net> (andy717(at)comcast.net)
matronics.com
;- List Contribution Web Site -
