alan99gill(at)yahoo.co.uk Guest
Posted: Mon Jan 02, 2012 1:43 am Post subject: Blue foam ribs |
----- Forwarded Message -----
To: Pulsar List <Pulsar-list(at)matronics.com>
Sent: Sunday, 1 January 2012, 11:27
Subject: Blue foam ribs
Happy New Year to everyone.
The subject of "blue foam ribs" has risen with-in our Pulsar fleet, and mainly relates to the Pulsar XP (series 1) where petrol (gas) fumes can/will degrade the blue foam ribs. I have very little detail as to the history when the introduction of the "brown (Clegicell) foam" started. At some stage, I think the brown foam (for rib 1 only) was introduced, and then all kits was provided with full set of brown foam ribs.
Any history (dates/year) re the introduction (or part off) the brown foam would be appreciated.
I am aware that the Pulsar II/III was not affected.
Thank you and regards
Alan Gill
UK Pulsar Squadron Support
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
freedom4life(at)xtra.co.n Guest
Posted: Mon Jan 02, 2012 2:12 am Post subject: Blue foam ribs |
I have serial number 403 and it has the Blue Foam dissolving ribs! Brian Anderson has a Pulsar XP not to far after mine and it has the Clegicell ribs. He will have to answer what serial number he has.
Cliff McChesney
Alan Gill
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Mon Jan 02, 2012 2:40 am Post subject: Blue foam ribs |
Alan
I just checked and the serial number of Brian Anderson’s pulsar is 456. So between 403 and 456 the ribs were changed. I think Brian’s Pulsar XP would have been one of the last that Aero Designs produced?
Cliff
Alan Gill
BIGJOHNTEX(at)aol.com Guest
Posted: Mon Jan 02, 2012 6:52 am Post subject: Blue foam ribs |
Serial 367 had the blue foam except for #1 (and maybe the one just outboard of the tank), which was brown foam.
John Reeves, original owner.
In a message dated 1/2/2012 4:12:27 A.M. Central Standard Time, freedom4life(at)xtra.co.nz writes:
Cliff McChesney
Alan Gill
ef="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-List
s.matronics.com/">http://forums.matronics.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
sonja.englert(at)juno.com Guest
Posted: Mon Jan 02, 2012 7:29 am Post subject: Blue foam ribs |
I have Pulsar XP s/n 298 with blue foam ribs (some replaced).
Sonja
Get Free Email with Video Mail & Video Chat!
http://www.juno.com/freeemail?refcd=JUTAGOUT1FREM0210
ccoulter(at)wavecable.com Guest
Posted: Mon Jan 02, 2012 8:17 am Post subject: Blue foam ribs |
On Mon, 2 Jan 2012 09:41:22 +0000 (GMT)
Alan Gill <alan99gill(at)yahoo.co.uk> wrote:
Alan Gill
Posted: Mon Jan 02, 2012 8:18 am Post subject: Blue foam ribs |
Alan Gill
My kit nr. is 452 and it had the brown ribs.
Clarke
mortweaver(at)sbcglobal.n Guest
Posted: Mon Jan 02, 2012 8:22 am Post subject: Blue foam ribs |
I have nearly 250 hours on a Pulsar XP with blue foam ribs and have experienced no fuel damage to ribs. During first 100 hours, I had to rework wing fuel tanks close out plate seal area on both wings 2 or 3 times. I fiber glassed wing root cuff seals on the fuselage to create a gap seal on both the upper and lower wing surfaces. It may very well be air flow while in flight, where there is in adequate gap seal (upper and lower surfaces), that poses the greatest risk for fuel vapor entering the interior of an affected wing. In the past, I have had puddles of gasoline on the floor area under my hangar parked Pulsar (due to leaking tank end plates). Upon removing wing inspection plates (not optional in my opinion) found no signs of blue wing foam deter-oration. The wing gap seal should extend all the way around the wing-fuselage intersection along the lower surface of wing root up to the wing flap.
Dave Weaver N912GR
--- On Mon, 1/2/12, sonja.englert(at)juno.com <sonja.englert(at)juno.com> wrote:
From: sonja.englert(at)juno.com <sonja.englert(at)juno.com>
Subject: Re: Fw: Blue foam ribs
To: pulsar-list(at)matronics.com
Date: Monday, January 2, 2012, 9:27 AM
--> Pulsar-List message posted by: "sonja.englert(at)juno.com (sonja.englert(at)juno.com)" <sonja.englert(at)juno.com (sonja.englert(at)juno.com)>
Sonja
http://wwsp; --> http://f= - List Contributionsp; -Matt Dralle, cs.com/contribution" target=_blank>http://www.matronics.com/contribution<=============
| [quote][b]
briana(at)xtra.co.nz Guest
Posted: Mon Jan 02, 2012 9:54 am Post subject: Blue foam ribs |
Alan,
My kit has all Klegcell ribs. Serial #456, delivered in April 1996. Oh my gosh - - that long ago !!
Brian
From: Alan Gill <alan99gill(at)yahoo.co.uk (alan99gill(at)yahoo.co.uk)>
To: Pulsar List <Pulsar-list(at)matronics.com (Pulsar-list(at)matronics.com)>
Alan Gill
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-List
| [b]
